Not able to renew certificates
Dear Team,
I am not able to renew certificate getting error.
blank to select all options shown (Enter 'c' to cancel): 20
Cannot extract OCSP URI from /etc/letsencrypt/archive/mail.ntsipl.com/cert9.pem
Certificate is due for renewal, auto-renewing...
Renewing an existing certificate for mail.ntsipl.com
http-01 challenge for mail.ntsipl.com
Challenge failed for domain mail.ntsipl.com
Domain: mail.ntsipl.com
Type: connection
Detail: 103.239.124.251: Fetching http://mail.ntsipl.com/.well-known/acme-challenge/2_fkHUh0A8JjVddLjxRWTKcqT_yMXOlRTC59Ceg2OFM: Error getting validation data
Welcome @jitendra.sharma In the future please post problems in the Help section. That will show you a form to provide info that we often need. I moved your topic there and we will later show that form if this post is not enough to help you.
Your mail.ntispl.com domain is not responding to HTTP requests on port 80. This is required to satisfy the HTTP Challenge you used previously to get the cert. It must have worked when you got the cert originally and any renewals. But, is no longer working.
The Let's Encrypt server reported this as "Error getting validation data". I saw connection problems from every testing tool I tried so it is not unique to Let's Encrypt.
I can reach that domain using HTTPS on port 443. Just not HTTP and port 80. Interestingly, the cert used for connections to the mail subdomain use a wildcard cert for *.ntispl.com
For example, see: Check website performance and response : Check host - online website monitoring
letsencrypt.txt (1.9 MB)
Dear Sir,
please check the logs. It's happening after iredadmin-pro upgradation
Dear Team,
Issue is resolved
Thanks
Would you please explain what you did to resolve this? It might help us instruct someone else in the future if this happens again. Thanks
