Not able to renew certificate with http-01
iotportal.esteeonline.com
certbot renew
certbot --force-renew
1: iotportal.esteeonline.com
blank to select all options shown (Enter ‘c’ to cancel):
http-01 challenge for iotportal.esteeonline.com
Waiting for verification…
Failed authorization procedure. iotportal.esteeonline.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://iotportal.esteeonline.com/.well-known/acme-challenge/******************************************: Timeout during connect (likely firewall problem)
    Domain: iotportal.esteeonline.com
    Type: connection
    Detail: Fetching
    http://iotportal.esteeonline.com/.well-known/acme-challenge/******************************:
I can login to a root shell on my machine (yes or no, or I don’t know): YEs
In order for a let’s Encrypt certificate to be renewed with http validation, you must have port 80 open and able to receive / respond to requests. As of now, the port is currently closed.
Please open the port and try again.
Thank you
Hi @seupure
there are a lot of old certificates visible (first from 2017-01-30).
Looks like you have used tls-sni-01 validation via port 443. That's not longer supported, so you have to use another challenge type.
Check
But http-01 validation requires an open port 80, your port 80 is closed. Not configured or blocked via a firewall or a missing router forward.
There is no answer ( https://check-your-website.server-daten.de/?q=iotportal.esteeonline.com ):
63.158.167.101 -14 10.027 T
Timeout - The operation has timed out
https://iotportal.esteeonline.com/
63.158.167.101 403 1.140 M
Forbidden
http://iotportal.esteeonline.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
63.158.167.101 -14 10.026 T
Visible Content:
A timeout means that there is a firewall or there is no vHost configured.
So create a vHost with that domain name and add it.
Then recheck your domain to see, if the two lines with the timeout answers.
These are outgoing connections.
That's required, but doesn't say something about incoming connections.
You can't check your incoming connection from your server.
Use a tool like https://check-your-website.server-daten.de/?q=iotportal.esteeonline.com to check that:
Forbidden
63.158.167.101 -14 10.023 T
Only timeouts, so http-01 validation can't work.
