My domain is: offgrid.technology
Used Acme Plugin for PFSense
MGMT_Cert_COLOFW1
Renewing certificate
account: Offgrid
server: letsencrypt-staging-2
/usr/local/pkg/acme/acme.sh --issue --domain 'colofw1.offgrid.technlogy' --webroot pfSenseacme --home '/tmp/acme/MGMT_Cert_COLOFW1/' --accountconf '/tmp/acme/MGMT_Cert_COLOFW1/accountconf.conf' --force --always-force-new-domain-key --reloadCmd '/tmp/acme/MGMT_Cert_COLOFW1/reloadcmd.sh' --log-level 3 --log '/tmp/acme/MGMT_Cert_COLOFW1/acme_issuecert.log'
Array
[path] => /etc:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin/
[PATH] => /etc:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin/
[folder] =>
[Fri Mar 22 03:52:20 +05 2024] Using CA: https://acme-staging-v02.api.letsencrypt.org/directory
[Fri Mar 22 03:52:20 +05 2024] Using pre generated key: /tmp/acme/MGMT_Cert_COLOFW1/colofw1.offgrid.technlogy/colofw1.offgrid.technlogy.key.next
[Fri Mar 22 03:52:20 +05 2024] Generate next pre-generate key.
[Fri Mar 22 03:52:21 +05 2024] Single domain='colofw1.offgrid.technlogy'
[Fri Mar 22 03:52:21 +05 2024] Getting domain auth token for each domain
[Fri Mar 22 03:52:22 +05 2024] Create new order error. Le_OrderFinalize not found. {
"type": "urn:ietf:params:acme:error:rejectedIdentifier",
"detail": "Error creating new order :: Cannot issue for "colofw1.offgrid.technlogy": Domain name does not end with a valid public suffix (TLD)",
"status": 400
[Fri Mar 22 03:52:22 +05 2024] Please check log file for more details: /tmp/acme/MGMT_Cert_COLOFW1/acme_issuecert.log
PfSense 2.7.2
Dedicated Server in a Colo
PfSense
or certbot-auto --version
if you're using Certbot):
TLD List:
https://www.iana.org/domains/root/db
https://www.iana.org/domains/root/db/technology.html
