bottebuona.sviluppo.host
acme-client -v -F bottebuona.sviluppo.host
acme-client: /tmp/server.key: generated RSA domain key
acme-client: https://acme-v02.api.letsencrypt.org/directory: directories
acme-client: acme-v02.api.letsencrypt.org: DNS: 172.65.32.248
acme-client: dochngreq: https://acme-v02.api.letsencrypt.org/acme/authz-v3/50131692840
acme-client: challenge, token: aJEHC15Mtvo7fSnw_Dn-s0dZ4x2E03Q6rSzKeJViZH4, uri: https://acme-v02.api.letsencrypt.org/acme/chall-v3/50131692840/neGPPw, status: 0
acme-client: /var/www/html/.well-known/acme-challenge/aJEHC15Mtvo7fSnw_Dn-s0dZ4x2E03Q6rSzKeJViZH4: created
acme-client: https://acme-v02.api.letsencrypt.org/acme/chall-v3/50131692840/neGPPw: challenge
acme-client: order.status 0
acme-client: challenge, token: aJEHC15Mtvo7fSnw_Dn-s0dZ4x2E03Q6rSzKeJViZH4, uri: https://acme-v02.api.letsencrypt.org/acme/chall-v3/50131692840/neGPPw, status: -1
acme-client: order.status -1
acme-client: DNS problem: SERVFAIL looking up CAA for sviluppo.host - the domain's nameservers may be malfunctioning
acme-client: bad exit: netproc(1577070): 1
Apache 2.4.51
CloudLinux OS 8.4
host.it (I'm representing them)
Yes, I'm the sysadmin
Yes, Directadmin 1.63.1
or certbot-auto --version
if you're using Certbot):
letsencrypt 2.0.24 (installed from directadmin), but whatever other tool give the same error.
Additional details:
The problem started to appear yesterday and only for the second-level domains of the sviluppo.host zone.
In our case, bottebuona.sviluppo.host is a second-level domain, with a zone containing records as:
www.bottebuona.sviluppo.host
and similar hosts. bottebuona.sviluppo.host itself, resolves to a public IP:
dick$ dig bottebuona.sviluppo.host
; <<>> dig 9.10.8-P1 <<>> bottebuona.sviluppo.host
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 35108
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;bottebuona.sviluppo.host. IN A
;; ANSWER SECTION:
bottebuona.sviluppo.host. 360 IN A 81.31.149.101
;; Query time: 102 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Wed Nov 17 11:24:43 CET 2021
;; MSG SIZE rcvd: 58
We never had DNSSEC on our zones and the error message appears a bit misleading. To note, we have other zones that we use as second-level domains, such as shared.host.it, used for the public hostnames of our hosting machines.
We also use letsencrypt to generate TLS certificates for the servers hostnames, like web001.shared.host.it and the certs are properly generated.
