Non Verified Connection
I have a site that was hosted at OVH, that handled Let’s Encrypt certificates automatically. A couple of days ago, I have moved to Amazon Web Services, and (obviously) i had to handle the certificates myself.
Before the migration everything went perfect, and after that i thought it was going perfect too, the certificates issued perfectly, and my browser detected it correctly. The problem is that some users have reported that they are having some issues with the certificate. It says that the website is non-secure. And I’ve seen myself that I’m getting the same error in Firefox running in my smartphone (Chrome in my smartphone works fine). The error i see is:
‘SEC_ERROR_UNKNOWN_ISSUER’.
Any idea?
My domain is: https://clubskodakodiaq.com and https://www.clubskodakodiaq.com
I ran this command: ./certbot-auto certonly --webroot -w /var/www/html/clubskodakodiaq -d clubskodakodiaq.com -d www.clubskodakodiaq.com
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/clubskodakodiaq.com.conf)
What would you like to do?
1: Keep the existing certificate for now
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
http-01 challenge for clubskodakodiaq.com
http-01 challenge for www.clubskodakodiaq.com
Using the webroot path /var/www/html/clubskodakodiaq for all unmatched domains.
Waiting for verification…
Generating key (2048 bits): /etc/letsencrypt/keys/0006_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0006_csr-certbot.pem
  • Congratulations! Your certificate and chain have been saved at
    /etc/letsencrypt/live/clubskodakodiaq.com/fullchain.pem. Your cert
    will expire on 2017-07-20. To obtain a new or tweaked version of
    this certificate in the future, simply run certbot-auto again. To
    non-interactively renew all of your certificates, run
    "certbot-auto renew"
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
My operating system is (include version): Amazon Linux:
Uname -a
Linux 4.4.51-40.58.amzn1.x86_64 #1 SMP Tue Feb 28 21:57:17 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
My web server is (include version): nginx version: nginx/1.10.2
My hosting provider, if applicable, is: AWS
I forgot to say that I tried to renew the certificate (in case there was something wrong with it), that seemed to go well, but nothing changed in the browsers.
Hello @jordii84,
Your problem is that you have not configured your webserver to include the intermediate certificate. Your nginx SSlCertificateFile directive should point to fullchain.pem instead of cert.pem. Once changed, restart or reload nginx and try again.
Cheers,
sahsanu
hello @sahsanu, thank you for your answer.
It seems it has corrected the issue. Thank you so much!
