One of our certificates has stopped renewing automatically, using the webroot mode. It’s for a basic WordPress site. No settings have (to my knowledge) been changed since the site was first set up. The site loads normally. The DNS is correctly set. The .well-known folder is present and accessible, I can visit it in browser. The site is correctly configured to redirect from port 80 to port 443, and testing with curl -I returns the expected headers. There are two other sites on the same server using Let’s Encrypt, both also WordPress sites, and both renewing successfully. I’ve tried manually triggering a renewal, and also wiping the certificate from Let’s Encrypt and trying again. None of it works. I’m officially stumped, and the site is going to go down when the certificate expires in about 3 days because it has HSTS enabled.
About the only clue I have is that when I try to run a renewal, I don’t see anything in the webserver logs showing the Let’s Encrypt validation servers trying to connect to the site. The other Let’s Encrypt certified sites on the server do show Let’s Encrypt related log entries when I attempt a renewal.
Can anyone suggest what might be up with it and how I might further diagnose and fix it? It looks very much as though the cause of the problem is on the Let’s Encrypt servers, but obviously I have no way of telling what’s happening there. Below is the renewal attempt output, showing one of the successful renewals (example.co.uk) and the failure (example.com):
root@host:~# certbot --dry-run renew
Processing /etc/letsencrypt/renewal/example.co.uk.conf
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
http-01 challenge for example.co.uk
http-01 challenge for www.example.co.uk
Generating key (2048 bits): /etc/letsencrypt/keys/0016_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0016_csr-certbot.pem
Processing /etc/letsencrypt/renewal/example.com.conf
http-01 challenge for example.com
http-01 challenge for www.example.com
Attempting to renew cert from /etc/letsencrypt/renewal/example.com.conf produced an unexpected error: Failed authorization procedure. www.example.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://example.com/.well-known/acme-challenge/70EFAavkqkzektth9JbNVqtU2q4NtHpx6dBhDb8Ouu8: Timeout, example.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://example.com/.well-known/acme-challenge/maTwAJhHllDdu-ik3nePuNHhLZIWAwJynAFGlyN3leQ: Timeout. Skipping.
The following certs were successfully renewed:
/etc/letsencrypt/live/example.co.uk/fullchain.pem (success)
The following certs could not be renewed:
/etc/letsencrypt/live/example.com/fullchain.pem (failure)
Domain: www.example.com
Type: connection
Detail: Fetching
Timeout
Domain: example.com
Type: connection
Detail: Fetching
Timeout
Any help will be gratefully received, as I’m at my wits’ end here! Thanks!
