Hi everyone!
I’m actualy building a nodejs proxy. I would like my proxy can (re-)generate my certificates with a list of domains.
But, I don’t want to use my filesystem for challenge or for certs storage. someone already used this package ?
example provided by package don’t work for me :
I don’t understand .well-known url, can you explain me ?
le.challenges[http-01].loopback should be defined as function (opts, domain, token, keyAuthorization, cb) { ... } and
should prove (by external means) that the ACME serv er challenge 'http-01' will succeed
le.challenges[tls-sni-01].loopback should be defined as function (opts, domain, token, keyAuthorization, cb) { ... }
and should prove (by external means) that the ACME s erver challenge 'tls-sni-01' will succeed
debug true
[le-store-certbot] certificates.check
Error: ENOENT: no such file or directory, open './certs/live/domain.fr/privkey.pem'
debug true
Error: ENOENT: no such file or directory, open './certs/live/local.dev/cert.pem'
debug undefined
[le-store-certbot] success reading arg.accountsDir
[le-store-certbot] regrs.length 1
[le-store-certbot] accountId: 79bb71d189792737c85fac45d0f29030
This Let's Encrypt / ACME server has been updated with urls that this client doesn't understand
{ 'key-change': 'https://acme-staging.api.letsencrypt.org/acme/key-change',
'new-authz': 'https://acme-staging.api.letsencrypt.org/acme/new-authz',
'new-cert': 'https://acme-staging.api.letsencrypt.org/acme/new-cert',
'new-reg': 'https://acme-staging.api.letsencrypt.org/acme/new-reg',
'revoke-cert': 'https://acme-staging.api.letsencrypt.org/acme/revoke-cert' }
debug true
The CA was unable to validate the file you provisioned.
- https://acme-staging.api.letsencrypt.org/acme/challenge/zJ2wapBXv2QcPKSqg1eIF4TswDLsIs3IrHJgNl7IJdQ/18472472 [invalid]
Invalid response from http://domain.fr/.well-known/acme-challenge/xnSuSodlSkcAhyMwdzOFhi0ScxUIuHddq8i4Ray9Tu0: "something">clique"
- https://acme-staging.api.letsencrypt.org/acme/challenge/zJ2wapBXv2QcPKSqg1eIF4TswDLsIs3IrHJgNl7IJdQ/18472473 [pending]
- https://acme-staging.api.letsencrypt.org/acme/challenge/zJ2wapBXv2QcPKSqg1eIF4TswDLsIs3IrHJgNl7IJdQ/18472474 [pending] null { identifier: { type: 'dns', value: 'domain.fr' },
status: 'invalid',
expires: '2016-12-27T20:22:35Z',
challenges:
[ { type: 'http-01',
status: 'invalid',
error: [Object],
uri: 'https://acme-staging.api.letsencrypt.org/acme/challenge/zJ2wapBXv2QcPKSqg1eIF4TswDLsIs3IrHJgNl7IJdQ/18472472',
token: 'xnSuSodlSkcAhyMwdzOFhi0ScxUIuHddq8i4Ray9Tu0',
keyAuthorization: 'xnSuSodlSkcAhyMwdzOFhi0ScxUIuHddq8i4Ray9Tu0.IvERhuKZFdFbNydLP6L_aG2Neg5zQiqS9mrk41SpaFs',
validationRecord: [Object] },
{ type: 'tls-sni-01',
status: 'pending',
uri: 'https://acme-staging.api.letsencrypt.org/acme/challenge/zJ2wapBXv2QcPKSqg1eIF4TswDLsIs3IrHJgNl7IJdQ/18472473',
token: 'jlPXOYVnqONXMB_RTwzdRYk_FM2WBYZvXgXO0V-fHyg' },
{ type: 'dns-01',
status: 'pending',
uri: 'https://acme-staging.api.letsencrypt.org/acme/challenge/zJ2wapBXv2QcPKSqg1eIF4TswDLsIs3IrHJgNl7IJdQ/18472474',
token: 'ZBiMb_JbSmzvP9ZbiqdauJ7rphDgR5ESh2Mlvy7AR1Y' } ],
combinations: [ [ 1 ], [ 2 ], [ 0 ] ] }
[Error]:
Error: The CA was unable to validate the file you provisioned.
[invalid] Invalid response from http://domain.fr/.well-known/acme-challenge/xnSuSodlSkcAhyMwdzOFhi0ScxUIuHddq8i4Ray9Tu0: "something">clique"
at handleErr (/home/m/test/node_modules/le-acme-core/lib/get-certificate.js:351:17)
at ensureValidation (/home/m/test/node_modules/le-acme-core/lib/get-certificate.js:226:16)
at Request._callback (/home/m/test/node_modules/le-acme-core/lib/get-certificate.js:208:13)
at Request.self.callback (/home/m/test/node_modules/request/request.js:186:22)
at emitTwo (events.js:106:13)
at Request.emit (events.js:191:7)
at Request.<anonymous> (/home/m/test/node_modules/request/request.js:1081:10)
at emitOne (events.js:96:13)
at Request.emit (events.js:188:7)
at IncomingMessage.<anonymous> (/home/m/test/node_modules/request/request.js:1001:12)
at IncomingMessage.g (events.js:292:16)
at emitNone (events.js:91:20)
at IncomingMessage.emit (events.js:185:7)
at endReadableNT (_stream_readable.js:974:12)
at _combinedTickCallback (internal/process/next_tick.js:74:11)
at process._tickCallback (internal/process/next_tick.js:98:9)
