Hello,
Below are my environment details:
Domain name: test1.telebu.io
Certificate provider: sslforfree.com
OS: Cent OS 7.x
NodeJS (Web server) version: 8.x
I installed NodeJS and running the node server with an example application as below:
const http = require(‘http’);
function handler(req, res) {
res.end(‘Hello World!’);
http.createServer(handler).listen(80);
I also setup the “authbind” to run my node server on standard ports i.e. 80 and 443. Now, I run this command: authbind node server.js
Now, my node server is running successfully. When I open the " http://test1.telebu.io " in the browser, “Hello World!” string is displaying successfully.
Now, coming to the Letsencrypt topic. As you suggested, I created the “.well-known” folder in my home folder and then created “acme-challenge” folder in side the “.well-known” folder and uploaded the generated file by you in to " /home/chandramouli/.well-known/acme-challenge/ " folder.
Problem:
Now, I need to validate. When I am trying to open " http://test1.telebu.io/.well-known/acme-challenge/filename " in the browser, I am getting “Hello World!” string (NodeJS application output), instead of your file output.
Please note that when I try to do “wget test1.telebu.io/.well-known/acme-challenge/” from any other system", I am getting the uploaded file successfully. For your information, I am new to NodeJS.
Please help me to resolve the issue.
Thanks in advance.
Best Regards,
Chandramouli.
