No matching distribution found for certbot-nginx==0.18.1
www.heyulinsite.top
./certbot-auto certonly --webroot …
Downloading http://mirrors.aliyun.com/pypi/packages/f5/90/23d9cb5d81d27e5027a8b8ad1464117ab50bad31d73f7d8f8df4fa1a5e55/acme-0.18.1-py2.py3-none-any.whl (99kB)
Collecting certbot-apache==0.18.1 (from -r /tmp/tmp.FntqV4jY28/letsencrypt-auto-requirements.txt (line 208))
Downloading http://mirrors.aliyun.com/pypi/packages/6c/bd/d24ea6885f66ac3cc8c58668c11543f8572c2053b7a6305059c37699be08/certbot_apache-0.18.1-py2.py3-none-any.whl (135kB)
Collecting certbot-nginx==0.18.1 (from -r /tmp/tmp.FntqV4jY28/letsencrypt-auto-requirements.txt (line 211))
Could not find a version that satisfies the requirement certbot-nginx==0.18.1 (from -r /tmp/tmp.FntqV4jY28/letsencrypt-auto-requirements.txt (line 211)) (from versions: 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.9.1, 0.9.2, 0.9.3, 0.10.0, 0.10.1, 0.10.2, 0.11.0, 0.11.1, 0.12.0, 0.13.0, 0.14.0, 0.14.1, 0.14.2, 0.15.0, 0.16.0, 0.17.0, 0.18.0)
No matching distribution found for certbot-nginx==0.18.1 (from -r /tmp/tmp.FntqV4jY28/letsencrypt-auto-requirements.txt (line 211))
nginx 1.12.1
centos6
xshell
kindly need your help. This is a problem while acquiring the cert through certbot int the period establishing env.
error output where establish the env is:No matching distribution found for certbot-nginx==0.18.1 (from -r /tmp/tmp.FntqV4jY28/letsencrypt-auto-requirements.txt (line 211))
certbot-auto will try to upgrade as part of the renewal command - are you aware of that?
can you run certbot-auto --version?
if so run the command again but add the --no-self-upgrade flag
From documentation: https://certbot.eff.org/docs/using.html#certbot-commands
–no-self-upgrade (certbot-auto only) prevent the certbot-auto script
from upgrading itself to newer released versions
(default: Upgrade automatically)
Andrei
Thanks Andrei! I worked as your suggestion,now the result is changed,but the error still exists.
1)run
./certbot-auto --no-self-upgrade --nginx
the output is:
Creating virtual environment…
Installing Python packages…
Installation succeeded.(it has never succeeded before,but this time it succeeded)
Error while running nginx -c /etc/nginx/nginx.conf -t.
nginx: [emerg] open() “/etc/nginx/nginx.conf” failed (2: No such file or directory)
nginx: configuration file /etc/nginx/nginx.conf test failed
The nginx plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError(‘Error while running nginx -c /etc/nginx/nginx.conf -t.\n\nnginx: [emerg] open() “/etc/nginx/nginx.conf” failed (2: No such file or directory)\nnginx: configuration file /etc/nginx/nginx.conf test failed\n’,)
2)omit last output error, run
** ./certbot-auto certonly --no-self-upgrade --webroot -w … -d …**
Then after input some information, I got the error:
An unexpected error occurred:
The request message was malformed :: Error creating new authz :: Name does not end in a public suffix
I tried many times, but still is not clear where is the key of the problem. Could you point out the key of the problem!
search what the public suffix list is (basically a list of valid domains) are you using something like .local in your config files
The easiest way may be to paste the log or the nginx config so other can have a look
Andrei
Thanks Andrei ! Here is the log and config
  1. the log of cerbot is :
    2017-09-14 01:44:52,072:DEBUG:acme.client:Storing nonce: cLVLvHJKf_oeRD_uyW2o1Rl_PLtPmrJ4jAkM0di6xlA
    2017-09-14 01:44:52,072:DEBUG:certbot.log:Exiting abnormally:
    ** File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 11, in **
    ** sys.exit(main())**
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/main.py”, line 755, in main**
    ** return config.func(config, plugins)**
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/main.py”, line 694, in certonly**
    ** lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)**
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/main.py”, line 82, in _get_and_save_cert**
    ** lineage = le_client.obtain_and_enroll_certificate(domains, certname)**
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/client.py”, line 357, in obtain_and_enroll_certificate**
    ** certr, chain, key, _ = self.obtain_certificate(domains)**
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/client.py”, line 318, in obtain_certificate**
    ** self.config.allow_subset_of_names)**
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/auth_handler.py”, line 66, in get_authorizations**
    ** self.authzr[domain] = self.acme.request_domain_challenges(domain)**
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/acme/client.py”, line 212, in request_domain_challenges**
    ** typ=messages.IDENTIFIER_FQDN, value=domain), new_authzr_uri)**
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/acme/client.py”, line 191, in request_challenges**
    ** response = self.net.post(self.directory.new_authz, new_authz)**
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/acme/client.py”, line 682, in post**
    ** return self._post_once(args, kwargs)
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/acme/client.py”, line 695, in _post_once
    ** return self._check_response(response, content_type=content_type)**
    ** File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/acme/client.py”, line 582, in _check_response**
    ** raise messages.Error.from_json(jobj)**
    Error: urn:acme:error:malformed :: The request message was malformed :: Error creating new authz :: Name does not end in a public suffix
2)the nginx config is :
server
** #listen 80;**
** listen 443 ssl;**
** #listen [::]:80 default_server ipv6only=on;**
** server_name studyssl.heyulinsite.top;**
** index index.html index.htm index.php;**
** #root /home/wwwroot/laravel/studylaravel/public;**
** root /home/wwwroot/smarty/htdocs;**
** #error_page 404 /404.html;**
** # Deny access to PHP files in specific directory**
** #location ~ /(wp-content|uploads|wp-includes|images)/.*.php$ { deny all; }**
** include enable-php.conf;**
** location /nginx_status**
** stub_status on;**
** access_log off;**
** location ~ .*.(gif|jpg|jpeg|png|bmp|swf)$**
** expires 30d;**
** location ~ .*.(js|css)?$**
** expires 12h;**
** location ~ /.well-known/acme-challenge/ {**
** allow all;**
** location ~ /.**
** deny all;**
** location / {**
** try_files $uri $uri/ /index.php?$query_string;**
** access_log /home/wwwlogs/access.log;**
