Why wouldn't it be necessary? Unless @giuseppe30 has /etc/
symlinked to /usr/local/etc/
or something.. Certbot expects all the files in /etc/letsencrypt
and as far as I know, it doesn't use "backup" locations if it doesn't find a valid dir under /etc/
I would suggest a reinstall (--keep
) attempt, but I have a feeling that @giuseppe30's nginx configuration may be nonstandard.
root@nc-jail:/usr/local/etc/letsencrypt/archive/cloud.lemovstudio.com # ls
cert1.pem chain1.pem fullchain1.pem privkey1.pem
root@nc-jail:/usr/local/etc/letsencrypt/archive/cloud.lemovstudio.com # certbot certificates --config-dir /usr/local/etc/letsencrypt
No certificates found.
ls -la /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com
root@nc-jail:~ # ls -la /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com
total 6
drwxr-xr-x 2 root wheel 3 Mar 24 18:52 .
drwxr-xr-x 3 root wheel 3 Mar 24 15:50 ..
---------- 1 root wheel 692 Mar 24 15:51 README
root@nc-jail:~ #
Is there an archive
missing here?
Let's recap...
sudo ls -lRa /usr/local/etc/letsencrypt
total 6
root@nc-jail:~ # ls -lRa /usr/local/etc/letsencrypt
total 37
drwxr-xr-x 9 root wheel 9 Mar 24 19:13 .
drwxr-xr-x 21 root wheel 35 Mar 24 12:41 ..
drwx------ 4 root wheel 4 Mar 24 13:14 accounts
drwxr-xr-x 3 root wheel 3 Mar 24 18:52 archive
drwxr-xr-x 2 root wheel 9 Mar 24 13:21 csr
drwx------ 2 root wheel 9 Mar 24 13:21 keys
drwxr-xr-x 3 root wheel 3 Mar 24 15:50 live
drwxr-xr-x 2 root wheel 2 Mar 24 12:42 renewal
drwxr-xr-x 5 root wheel 5 Mar 24 12:41 renewal-hooks
/usr/local/etc/letsencrypt/accounts:
total 10
drwx------ 4 root wheel 4 Mar 24 13:14 .
drwxr-xr-x 9 root wheel 9 Mar 24 19:13 ..
drwx------ 3 root wheel 3 Mar 24 13:14 acme-staging-v02.api.letsencrypt.org
drwx------ 3 root wheel 3 Mar 24 12:41 acme-v02.api.letsencrypt.org
/usr/local/etc/letsencrypt/accounts/acme-staging-v02.api.letsencrypt.org:
total 2
drwx------ 3 root wheel 3 Mar 24 13:14 .
drwx------ 4 root wheel 4 Mar 24 13:14 ..
drwx------ 3 root wheel 3 Mar 24 13:14 directory
/usr/local/etc/letsencrypt/accounts/acme-staging-v02.api.letsencrypt.org/directory:
total 2
drwx------ 3 root wheel 3 Mar 24 13:14 ..
drwx------ 2 root wheel 5 Mar 24 13:14 0498dd1fb0907db28549e4126a34b824
/usr/local/etc/letsencrypt/accounts/acme-staging-v02.api.letsencrypt.org/directory/0498dd1fb0907db28549e4126a34b824:
total 7
drwx------ 2 root wheel 5 Mar 24 13:14 .
-rw-r--r-- 1 root wheel 67 Mar 24 13:14 meta.json
-r-------- 1 root wheel 1632 Mar 24 13:14 private_key.json
-rw-r--r-- 1 root wheel 86 Mar 24 13:14 regr.json
/usr/local/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org:
total 2
drwx------ 3 root wheel 3 Mar 24 12:41 .
drwx------ 3 root wheel 3 Mar 24 12:41 directory
/usr/local/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory:
total 2
drwx------ 3 root wheel 3 Mar 24 12:41 ..
drwx------ 2 root wheel 5 Mar 24 12:41 6136119b947f7ce7cdf61dd3e9da79c9
/usr/local/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory/6136119b947f7ce7cdf61dd3e9da79c9:
total 11
drwx------ 2 root wheel 5 Mar 24 12:41 .
-rw-r--r-- 1 root wheel 111 Mar 24 12:42 meta.json
-r-------- 1 root wheel 1632 Mar 24 12:41 private_key.json
-rw-r--r-- 1 root wheel 79 Mar 24 12:41 regr.json
/usr/local/etc/letsencrypt/archive:
total 10
drwxr-xr-x 3 root wheel 3 Mar 24 18:52 .
drwxr-xr-x 2 root wheel 6 Mar 24 19:12 cloud.lemovstudio.com
/usr/local/etc/letsencrypt/archive/cloud.lemovstudio.com:
total 19
drwxr-xr-x 2 root wheel 6 Mar 24 19:12 .
drwxr-xr-x 3 root wheel 3 Mar 24 18:52 ..
---------- 1 root wheel 1862 Mar 24 15:51 cert1.pem
---------- 1 root wheel 1586 Mar 24 15:51 chain1.pem
---------- 1 root wheel 3448 Mar 24 15:51 fullchain1.pem
---------- 1 root wheel 1704 Mar 24 15:51 privkey1.pem
/usr/local/etc/letsencrypt/csr:
total 49
drwxr-xr-x 2 root wheel 9 Mar 24 13:21 .
-rw-r--r-- 1 root wheel 932 Mar 24 12:42 0000_csr-certbot.pem
-rw-r--r-- 1 root wheel 932 Mar 24 12:56 0001_csr-certbot.pem
-rw-r--r-- 1 root wheel 932 Mar 24 12:58 0002_csr-certbot.pem
-rw-r--r-- 1 root wheel 932 Mar 24 13:09 0003_csr-certbot.pem
-rw-r--r-- 1 root wheel 985 Mar 24 13:11 0004_csr-certbot.pem
-rw-r--r-- 1 root wheel 932 Mar 24 13:12 0005_csr-certbot.pem
-rw-r--r-- 1 root wheel 932 Mar 24 13:21 0006_csr-certbot.pem
/usr/local/etc/letsencrypt/keys:
total 49
drwx------ 2 root wheel 9 Mar 24 13:21 .
-rw------- 1 root wheel 1704 Mar 24 12:42 0000_key-certbot.pem
-rw------- 1 root wheel 1704 Mar 24 12:56 0001_key-certbot.pem
-rw------- 1 root wheel 1708 Mar 24 12:58 0002_key-certbot.pem
-rw------- 1 root wheel 1704 Mar 24 13:09 0003_key-certbot.pem
-rw------- 1 root wheel 1704 Mar 24 13:11 0004_key-certbot.pem
-rw------- 1 root wheel 1704 Mar 24 13:12 0005_key-certbot.pem
-rw------- 1 root wheel 1704 Mar 24 13:21 0006_key-certbot.pem
/usr/local/etc/letsencrypt/live:
total 10
drwxr-xr-x 2 root wheel 3 Mar 24 18:52 cloud.lemovstudio.com
/usr/local/etc/letsencrypt/live/cloud.lemovstudio.com:
total 6
/usr/local/etc/letsencrypt/renewal:
total 9
drwxr-xr-x 2 root wheel 2 Mar 24 12:42 .
/usr/local/etc/letsencrypt/renewal-hooks:
total 11
drwxr-xr-x 5 root wheel 5 Mar 24 12:41 .
drwxr-xr-x 2 root wheel 2 Mar 24 12:41 deploy
drwxr-xr-x 2 root wheel 2 Mar 24 12:41 post
drwxr-xr-x 2 root wheel 2 Mar 24 12:41 pre
/usr/local/etc/letsencrypt/renewal-hooks/deploy:
total 1
drwxr-xr-x 2 root wheel 2 Mar 24 12:41 .
drwxr-xr-x 5 root wheel 5 Mar 24 12:41 ..
/usr/local/etc/letsencrypt/renewal-hooks/post:
total 1
/usr/local/etc/letsencrypt/renewal-hooks/pre:
total 1
@giuseppe30 Did you do the ln -s
steps?
No, not necessary for relative links.
Don't those relative commands expect the pems to be in the /usr/local/etc/letsencrypt
folder? Am I losing my marbles?
Why not this?
cd /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com
ln -s ../../archive/cloud.lemovstudio.com/cert1.pem cert.pem
ln -s ../../archive/cloud.lemovstudio.com/chain1.pem chain.pem
ln -s ../../archive/cloud.lemovstudio.com/fullchain1.pem fullchain.pem
ln -s ../../archive/cloud.lemovstudio.com/privkey1.pem privkey.pem
yes sorry, missing ln -s
total 37
drwxr-xr-x 9 root wheel 9 Mar 24 19:20 .
total 10
drwxr-xr-x 9 root wheel 9 Mar 24 19:20 ..
total 2
total 2
total 7
total 2
total 2
total 11
total 10
total 19
total 49
total 49
total 18
drwxr-xr-x 2 root wheel 7 Mar 24 19:20 cloud.lemovstudio.com
total 16
drwxr-xr-x 2 root wheel 7 Mar 24 19:20 .
lrwxr-xr-x 1 root wheel 15 Mar 24 19:20 cert.pem -> ../../cert1.pem
lrwxr-xr-x 1 root wheel 16 Mar 24 19:20 chain.pem -> ../../chain1.pem
lrwxr-xr-x 1 root wheel 20 Mar 24 19:20 fullchain.pem -> ../../fullchain1.pem
lrwxr-xr-x 1 root wheel 18 Mar 24 19:20 privkey.pem -> ../../privkey1.pem
total 9
total 11
total 1
total 1
total 1
root@nc-jail:~ #
cat /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/cert.pem
root@nc-jail:~ # cat /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/cert.pem
cat: /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/cert.pem: No such file or directory
root@nc-jail:~ #help
mh...
That's what I figured.
Then...
-----BEGIN CERTIFICATE-----
MIIFMTCCBBmgAwIBAgISAz74x8xixbRqf08VajkvlP+DMA0GCSqGSIb3DQEBCwUA
MDIxCzAJBgNVBAYTAlVTMRYwFAYDVQQKEw1MZXQncyBFbmNyeXB0MQswCQYDVQQD
EwJSMzAeFw0yMTAzMTIxNTM4NTNaFw0yMTA2MTAxNTM4NTNaMCAxHjAcBgNVBAMT
FWNsb3VkLmxlbW92c3R1ZGlvLmNvbTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCC
AQoCggEBAKsaYSQyuo53T49vnsTMoDja9VO6+KrYLhqvkt7ur/9Egw2d6FuGOIc4
e6ShIbnuCmrwHM/siDtB37crNvTen14pVjvNDEqhkkPvtB4rEhOM1QJ3ZoqyeF5+
wS3Ulf5RDMG162uAgNLytzciQhN5HY8+av9CZzJNRxm5smRZ0E1cdNB6eiwFrrBK
K4SIraiDSMlRrzrX97XCz3gUv/4iib+PrHLEcl5IJNG19AUOmEpoJhnBkUHo0W6/
OTfQpmox7KCseWGvuxw8hb04iXAJNdGSOqMqxF81aYqWv9XGmMp7/xv0fxFQWtHx
JitlycsYVIiuBbn9kd4BiOzHCeMNVDMCAwEAAaOCAlEwggJNMA4GA1UdDwEB/wQE
AwIFoDAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIwDAYDVR0TAQH/BAIw
ADAdBgNVHQ4EFgQUSSaKT/87PLuA/b7Ax4lvEX4BJNQwHwYDVR0jBBgwFoAUFC6z
F7dYVsuuUAlA5h+vnYsUwsYwVQYIKwYBBQUHAQEESTBHMCEGCCsGAQUFBzABhhVo
dHRwOi8vcjMuby5sZW5jci5vcmcwIgYIKwYBBQUHMAKGFmh0dHA6Ly9yMy5pLmxl
bmNyLm9yZy8wIAYDVR0RBBkwF4IVY2xvdWQubGVtb3ZzdHVkaW8uY29tMEwGA1Ud
IARFMEMwCAYGZ4EMAQIBMDcGCysGAQQBgt8TAQEBMCgwJgYIKwYBBQUHAgEWGmh0
dHA6Ly9jcHMubGV0c2VuY3J5cHQub3JnMIIBBQYKKwYBBAHWeQIEAgSB9gSB8wDx
AHcAlCC8Ho7VjWyIcx+CiyIsDdHaTV5sT5Q9YdtOL1hNosIAAAF4J04cswAABAMA
SDBGAiEA01ti1Ej+dKDH5TieZLjGqXmBttcxz1r7aj4KZDu+VB4CIQDN5VROHpQu
lD2BtaywKW7Vx36Ohw6lZElHo3b/cKvUqQB2APZclC/RdzAiFFQYCDCUVo7jTRMZ
M7/fDC8gC8xO8WTjAAABeCdOHLIAAAQDAEcwRQIgG5xxUTWRVtvufnnhG/gH1H7J
9CaXnwqP2N1AAOnKfdICIQCAomXTgiTH1dc0dMdcoK9ilQzDdfj+dGjWYYmB4Oty
eTANBgkqhkiG9w0BAQsFAAOCAQEAX0FOcUbx94YmpP6XW/7Ocane0KaZ857p7Ti3
7k6q4Cvd45xAFBqoI4pqkvG0DsX5HvhmCqabXVwyXxq7IhZzT3xq82wq9H7d2FND
bm6DRQfN/asEAXpGPgk8UUdrxXMsx2tR6uhwXsK58GODU2Ao6Swfki4sBiOsHJV4
tFBvSLshYY4oWerR2yDgqJ7hxgkmS8U3zqs6gO2fI18HDGU8TtpF+7+wd/ESrQ92
2iDMqjlC/FAFe543E4TUHpDgDt/QZR6tvBvotJ3aqvU2VpQU2E1R4GNtCkD/gPAe
SdcYFRKnq88YnoK3z4qf3FZvWips4jbFiXA69gy6nuTVo7IhgA==
-----END CERTIFICATE-----
root@nc-jail:~ #
much better!
