root@nc-jail:~ # certbot certificates --config-dir /usr/local/etc/letsencrypt
No certificates found.
root@nc-jail:~ #
root@nc-jail:~ #
Because that would give incorrect symbolic links?
/live/certname/
is two path-lengths, thus two ..
in the ../../
I think @Osiris is probably right about the renewal configuration files.
Ah, yes, the whole renewal file is missing..
That's a #()#()$ to rebuild
Oh, euh, because I focused on the incorrect part and you were right?
Any way, all this trouble for almost nothing: without a renewal file, certbot doesn't recognise the files at all...
You're probably better of running certbot from the top again.. I didn't realise the renewal file was missing completely, I assumed using --config-dir
was enough.
so regenerate certificate ?
first I need to clean up the live and archive folders ?
Color me purple...
Osiris, you admitted a mistake. Hellfire shall rain forth. Take cover!
So... once more... with feeling?
sudo certbot certonly --nginx -d "cloud.lemovstudio.com" --dry-run --config-dir /usr/local/etc/letsencrypt
root@nc-jail:~ # certbot certonly --nginx -d "cloud.lemovstudio.com" --dry-run --config-dir /usr/local/etc/letsencrypt
Could not choose appropriate plugin: The requested nginx plugin does not appear to be installed
To be fair, it's very rare that I see @Osiris make a mistake. His track record is certainly better than my own.
Yes, unfortunately that's the best method now, sorry for the inconvenience. Rebuilding a renewal file from scratch is, well.. Not so easy. Although one could try:
cat > /usr/local/etc/letsencrypt/renewal/cloud.lemovstudio.com.conf <<EOF
cert = /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/cert.pem
privkey = /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/privkey.pem
chain = /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/chain.pem
fullchain = /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/fullchain.pem
version = 1.13.0
archive_dir = /usr/local/etc/letsencrypt/cloud.lemovstudio.com
# Options and defaults used in the renewal process
[renewalparams]
installer = nginx
authenticator = nginx
rsa_key_size = 4096
account = 6136119b947f7ce7cdf61dd3e9da79c9
EOF
Although that's just from the wrist and makes a few assumptions, such as a working nginx plugin.
Uh.. oh. Hmm...
so...
certbot --version
root@nc-jail:~ # certbot --version
certbot 1.13.0
It's from some kind of TrueNAS Nextcloud something..
How did you install certbot @giuseppe30 ? Or was it pre-installed?
usually I use this
root@nc-jail:~ # certbot -d cloud.lemovstudio.com --manual --preferred-challenges dns certonly --dry-run
Hmm, who brought nginx in the play here, did you do that @griffin ?
@giuseppe30 You could repeat those steps. I'll edit my manually crafted renewal configuration file above to reflect this, might you still be interested.
Ouch. Manual DNS validation... Not uncommon with NAS though.
for installation use
pkg install py37-certbot
Yeah. I asked about his webserver before. Should've asked the method being used. My bad.
