I think that only the later ones are numbered. I think the original ones aren't. I could be wrong though. We'll find out from update_symlinks. ![]()
@griffin You're wrong
If update_symlinks can't find them then I'm wrong.
root@nc-jail:~ # certbot update_symlinks
root@nc-jail:~ # certbot certificates
No certificates found.
root@nc-jail:~ #
Even if update_symlinks works, I've helped someone recently where certbot would give a Python error due to the fact someone manually messed with the /archive/ folder because of the missing number suffix.
Could you give us the output of:
ls -l /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/
sudo ls -la /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/
Great minds think alike!
root@nc-jail:~ # ls -la /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/
total 6
drwxr-xr-x 2 root wheel 3 Mar 24 18:52 .
drwxr-xr-x 3 root wheel 3 Mar 24 15:50 ..
---------- 1 root wheel 692 Mar 24 15:51 README
root@nc-jail:~ #
update_symlinks probably requires a functional renewal configuration file.
Let's do it manually. First we rename the files with the number suffix, then we make the symlinks:
rename ".pem" "1.pem" /usr/local/etc/letsencrypt/archive/cloud.lemovstudio.com/*
cd /usr/local/etc/letsencrypt/live/cloud.lemovstudio.com/
ln -s ../../cert1.pem cert.pem
ln -s ../../chain1.pem chain.pem
ln -s ../../fullchain1.pem fullchain.pem
ln -s ../../privkey1.pem privkey.pem
Now test certbot please, you probably need to use --config-dir /usr/local/etc/letsencrypt
Yep. Need to try renaming them with 1's after each.
That's certainly possible. Probably easier just to grab new certs.
What webserver you using? Apache, nginx?
I use ngix
try this:
sudo certbot certonly --nginx -d "cloud.lemovstudio.com" --dry-run
I think your port 80 is timing out though.
I've typed some instructions above worth trying first
Edit took some time
You guys were quick with the new replies ![]()
ok go slow pls
These are the instructions:
test with this:
certbot certificates --config-dir /usr/local/etc/letsencrypt
I'm hoping the config-dir parameter isn't actually needed. That's gonna become super annoying.
