Nginx (https) virtual host not recognized after running certbot
My domain is:map.netronline.com
I ran this command:certbot --nginx --cert-name map -d map.netronline.com
It produced this output:installed successfully
My web server is (include version):nginx/1.14.2
The operating system my web server runs on is (include version):Debian/buster
My hosting provider, if applicable, is:our own
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):1.18.0
I have 4 sites running on the same production server, all SSL'd by certbot, and have been for over a year. I went to add the map. subdomain the usual way, but after the cert was successfully installed, nginx now re-directs the 443 to the default site rather than the new map. site. I've been trying everything over the last couple days with no luck. It appears that the 443 server block in my nginx conf for the map. site is being ignored by nginx. With no errors or debugging options, I don't know what to try next.
Hi @evanb,
For this problem, I think it would be helpful to post your nginx configuration:
sudo nginx -T
Here ya go, thanks!
nginx.conf.txt (21.9 KB)
Weird!
I think what it might be is that you have a mixture of listen bind addresses and modes:
listen 192.168.2.96:443;
listen 192.168.2.96:443 ssl http2;
listen 443 ssl;
nginx can do some funny things sometimes if you mix protocols on a single port.
What I would suggest is making things the same across each of your virtual hosts.
You'll notice that the map one is the odd one out, which makes me suspect this as the cause.
I put a lot of trust in the conf that certbot was creating so didn't suspect that. However, I just now changed the map. block to the following:
listen 192.168.2.96:443 ssl ipv6only=on;
...AND IT WORKED!!!!
Thank you so much! ...and for such a quick reply.
