Nginx redirects to default site after using certbot
My domain is: oslopeace19.no
sudo certbot --nginx -d oslopeace19.no
nginx version: nginx/1.14.0 (Ubuntu)
Ubuntu 18.04.3 LTS
Yes
No
certbot 0.31.0
Hello, I wanted to move a WordPress site to a different domain, I set the new domian in WordPress and have verified that the domain is set correctly in the WordPress settings, then I added the new domain in my nginx conf file for the site and ran certbot on the new domain, but now whenver I try to access the new domain nginx just redirects me to the default site instead of the actual site I want to open. I’ve attached my nginx conf file, I’ve tried to make many, many changes to it to fix this problem so it may contain some weird things.
https://dpaste.de/9PwC
I tried writing the part from line 56-61 myself again and manually set the correct HTTPS certs, but this did not fix the problem.
output from ls of myt /etc/letsencrypt/live/oslopeace19 folder
ls oslopeace19.no
cert.pem chain.pem fullchain.pem privkey.pem README
the letsencrypt folder contains three certificates for this site, one for the development domain, and two that have come from my trying to run certbot
# ls|  grep oslopeace
oslopeace19.fossekalltek.no
oslopeace19.no
oslopeace19.no-0001
Any ideas on what could be causing this issue?
edit: results from curl says the site is moved permanently
301 Moved Permanently
I see that you have correctly setup your Nginx plain http host, but your HTTPS host does not contain a server directive.
Please try to add your domain / host on that config and reload Nginx.
Thank you
by server directive do you mean ‘server_name’? I thought I could only have one of those per file, when I tried to add another nginx complained when I ran “sudo nginx -t”
Could you be a more specific on where I should add the second " server_name oslopeace19.no www.oslopeace19.no;" line?
You could only have one server_name directive per virtual host.
(The one that starts with server{ and ends with })
So since you have two servers in the config file, you should be able to add server_name in the first virtual host config.
See the below Pastebin for your reference: https://pastebin.com/cc8BF1mV
The only difference is that the first server directive does not have a server name, which is why it doesn’t work. (Since Nginx can’t find the website you are trying to visit)
Thank you
Thank you for your clearifaction and example config file, but I still have the same issue. When running your exact config file Nginx gives out the following warnings when running “sudo nginx -t”
nginx: [warn] conflicting server name "oslopeace19.no" on [::]:443, ignored
nginx: [warn] conflicting server name "oslopeace19.no" on 0.0.0.0:443, ignored
Using curl I still get the same “301 moved permanently” error
Ok.
Two more points:
  1. The 301 error is not an error, it’s a redirection that should redirect you to the “secure” https version of the site. You could use curl -L to follow redirects.
  2. The warning message stated is that you’ve already specified your https virtual host on another file.
Could you please try to dump your whole Nginx virtual hosts and share it to another text links?
use nginx -T to dump all your running configs…
Thank you
Full dump here https://dpaste.de/CmAh
Just update you here.
I’m still sorting the Nginx configuration file you provided… and still need some time.
No problem, I found some duplication error, so please use this file instead https://dpaste.de/707O
Still have the same issue though, tried to remove HTTPS certs in my latest config.
Not quite sure what I did, but I re-wrote the conf file for the tenth time today. Now the site is working as intended, I don’t like to read forum posts where OP just says “it works now”
But it does, and I have no idea why. Thank you for your help stevenzhu!
Glad it works :slight_smile:
