New with Acme4J and having problems with Challenge
HHelp with this. I was assigned this task and it's my first time working with ACME4J. The report says that the jks file isn't being generated, but this is a process that happens after the validation against the Acme server. But the challenge is failing saying that the tokens doesn't match, but until the update execution, the token is the same as the expected by the server.
My domain is: editdb.rwscheckout.com
challenge.trigger();
// attempt to pass the test 6 times (we only wanna spend about 30 secs total for
// each account)
for ( int i = 0; i < 6; i++ )
    challenge.update();
    // If the status is invalid, something went wrong, so it should be investigated
if ( challenge.getStatus() == Status.VALID || challenge.getStatus() == Status.INVALID )
    break;
    Thread.sleep(5_000);
if ( challenge.getStatus() == Status.VALID )
    ACME_LETS_ENCRYPT_STREAM.println(prefix + "challenge passed for account: " +
            domain);
    return true;
else
    return false;
json response: The key authorization file from the server did not match this challenge. Expected "D-EZIRAQejzL7GWS7IPR8d1Lc8c85Hs7MKTcEqz8grI.cWGMCIOzT7u8CnLd213wJQv_nSa9TZqPskPj3skx5BQ" (got "ksYprfcSgvybAGcksLu0IYKr4RN5v66v9VS3DJQvWTw.cWGMCIOzT7u8CnLd213wJQv_nSa9TZqPskPj3skx5BQ")
My web server is (include version): Don't really know
The operating system my web server runs on is (include version): Don't know either
My hosting provider, if applicable, is: ?
I can login to a root shell on my machine (yes or no, or I don't know): No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): ?
The problem seems to be somewhere before your code extract, when you create the http-01 challenge file. If I get the error message right, the server actually fetches the correct .well-known/acme-challenge file, but it has the wrong content (proabably of a different challenge).
There is an example at the acme4j documentation about how to create a http-01 challenge: Example - acme4j .
