Need unblock my IP---thanks for your help
My domain is: www.da-fa.tk
I ran this command: caddy
It produced this output: Activating privacy features… 2019/10/09 11:31:53 get directory at ‘https://acme-v02.api.letsencrypt.org/directory’: acme: error: 0 :: GET :: https://acme-v02.api.letsencrypt.org/directory :: urn:ietf:params:acme:error:rateLimited :: Your IP, 140.238.48.104, has been blocked due to ridiculously excessive traffic. Once this is corrected you may request this be reviewed on our forum https://community.letsencrypt.org , url:
My web server is (include version): Caddy
The operating system my web server runs on is (include version): redhat7 4.14.35-1902.5.2.2.el7uek.x86_64
My hosting provider, if applicable, is: VPS
Hi @ChenDaMin
there are some other topics, may be the same problem. Caddy plus that `ridiculously excessive traffic'.
Check
Do you use V2Ray?
yes, I use V2ray + Caddy
This is a new setup server, i don’t understand “ridiculously excessive traffic” .
Looks like a general problem with that V2ray, so that tool produces an endless loop.
wait,… I try close v2ray. and try again.
I closed v2ray but the issue still exists. :joy:
@ChenDaMin,
We’re aware of issues with V2Ray. Until we explicitly remove the ratelimit for your IP, you will continue receiving the ratelimit.
Can you please post the following information:
  • Your full Caddyfile (without changes)
  • Your full logs (from your Caddy process log and/or systemd/journalctl)
  • Full and complete error messages
It’s not a V2Ray issue. The systemd config file for Caddy (caddy.service) is the problem (see here: https://github.com/233boy/v2ray/issues/347) and should have been fixed. If you use the script by 233boy, upgrading to the latest version might help. Of course, your ip ban needs to be removed first, I think.
