Need to implement on oracle Application EBS suite 12.2.6 with 12c database
My domain is: Oracle applications (http://oar12apc.consolidated.work:8000)
I ran this command: Did not run any command
It produced this output: not applicable
My operating system is (include version): RHEL 7
My hosting provider, if applicable, is: Not applicable
I can login to a root shell on my machine (yes or no, or I don’t know): Yes i have root ssh access
Hi @sudheer821
can you please explain the problem a bit more
I am assuming you are wanting to work LetsEcnrypt into a Oracle EBS application?
If so - have you done any research on how to configure EBS for SSL?
Do you have a plan of attack?
What are you looking for with assistance?
The fact you have not run any commands suggests to me you may not have done the groundwork??
Andrei
have a read of this
i believe EBS is a java application so this may be relevant
Hi Team,
The oracle EBS url is http://voar12a.consolidatedshoe.com:8000 – For the first time.
So i changed it back to http://voar12a.consolidatedshoe.com. So now i could able to connect using two links
http://voar12a.consolidatedshoe.com:80 and http://voar12a.consolidatedshoe.com.
I did the following::
  1. [root@voar12a /]# mkdir certbot
    [root@voar12a /]# cd certbot/
    [root@voar12a certbot]# wget https://dl.eff.org/certbot-auto
  2. [root@voar12a certbot]# ./certbot-auto
  3. SO the last output of the above lines are as follows::
Complete!
Creating virtual environment…
Installing Python packages…
Installation succeeded.
Failed to find apache2ctl in PATH: /usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
  1. And i ran the following::
[root@voar12a certbot]# ./certbot-auto certonly --webroot -w /adfa/domains/voar12a/www/root -d voar12a.consolidatedshoe.com
  1. [root@voar12a certbot]# ./certbot-auto certonly --webroot -w /adfa/domains/voar12a/www/root -d consolidatedshoe.com
    Output of the above command::
    http-01 challenge for consolidatedshoe.com
    Using the webroot path /adfa/domains/voar12a/www/root for all unmatched domains.
    Waiting for verification…
    Failed authorization procedure. consolidatedshoe.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to consolidatedshoe.com
    Domain: consolidatedshoe.com
    Type: connection
    Detail: Could not connect to consolidatedshoe.com
    that you are serving files from the webroot path you provided
Please provide the resolution. Need to implement on Production.
Thanks,
Hi Andrei,
–> Yes because oracle charge for CA. where as LetsEncrypt provide the certificate for free and it is widely used by all.
–> My EBS url is http;//voar12a.consolidatedshoe.com:8000. I came to know that LE looks for http;//voar12a.consolidatedshoe.com (not the port). So i changed the EBS url from http;//voar12a.consolidatedshoe.com:8000 to http;//voar12a.consolidatedshoe.com.
Commands run?
My OS is RHEL 7, i ran the following and installed the rpms
a) [root@oar12apc apps]# mkdir certbot
[root@oar12apc apps]# cd certbot/
[root@oar12apc certbot]# ls
[root@oar12apc certbot]# wget https://dl.eff.org/certbot-auto
–2017-02-28 09:08:57-- https://dl.eff.org/certbot-auto
b) [root@oar12apc certbot]# ls
certbot-auto
[root@oar12apc certbot]# chmod a+x certbot-auto (given the permissions)
[root@oar12apc certbot]# ll
total 48
-rwxr-xr-x. 1 root root 46789 Feb 7 18:15 certbot-auto
c) [root@oar12apc certbot]# ./certbot-auto
Bootstrapping dependencies for RedHat-based OSes…
yum is /usr/bin/yum
Loaded plugins: amazon-id, rhui-lb, search-disabled-repos
Repodata is over 2 weeks old. Install yum-cron? Or run: yum makecache fast
rhui-REGION-client-config-server-7 | 2.9 kB 00:00
rhui-REGION-rhel-server-extras | 3.4 kB 00:00
…installed the RPM’s (packages)
…verified, upgraded, installed the dependencies
Failed to find apachectl in PATH: /usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
Certbot doesn’t know how to automatically configure the web server on this system. However, it can still get a certificate for you. Please run “certbot-auto certonly” to do so. You’ll need to manually configure your web server to use the resulting certificate
d) [root@voar12a certbot]# ./certbot-auto certonly --webroot -w /adfa/domains/voar12a/www/root -d consolidatedshoe.com
    Type: connection
–> ./certbot-auto certonly --webroot -w /adfa/domains/voar12a/www/root -d consolidatedshoe.com
/adfa/domains/voar12a/www/root – i created this directory structure. And got .Well-Known directory with empty got created.
As of now i am facing the above issue to get the certificate.
Please help
Thanks,
