I’m using Debian 8.6 with Nginx 1.6.2, and my domain is reinsmidt.com
I think I have my nginx config correct but I am not able to connect through https. I do have port 443 open in my firewall.
Here are the relevant parts from my nginx config:
listen 443 ssl;
listen 80;
server_name reinsmidt.com;
ssl on;
ssl_certificate /etc/letsencrypt/live/reinsmidt.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/reinsmidt.com/privkey.pem;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers HIGH:!aNULL:!MD5;
location ~ /.well-known {
allow all;
I looked at my site using openssl and here are the results:
openssl s_client -connect reinsmidt.com:443 -servername reinsmidt.com
CONNECTED(00000003)
3073996476:error:140790E5:SSL routines:SSL23_WRITE:ssl handshake failure:s23_lib.c:177:
no peer certificate available
SSL handshake has read 0 bytes and written 311 bytes
New, (NONE), Cipher is (NONE)
Compression: NONE
Expansion: NONE
SSL-Session:
Protocol : TLSv1.2
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
PSK identity: None
PSK identity hint: None
SRP username: None
Start Time: 1476939349
Timeout : 300 (sec)
Verify return code: 0 (ok)
Any help would be greatly appreciated!
