ERR_SSL_PROTOCOL_ERROR with Nginx
Hi, I have kind of a reverse proxy setup with Nginx, here’s my config:
        listen 80;
        server_name discourse.jonaharagon.com;
        return 301 https://discourse.jonaharagon.com$request_uri;
        listen 443;
        ssl_certificate /etc/letsencrypt/live/discourse.jonaharagon.com/fullchain.pem;
        ssl_certificate_key /etc/letsencrypt/live/discourse.jonaharagon.com/privkey.pem;
                proxy_pass      http://discourse.jonaharagon.com:25654/;
                proxy_read_timeout      90;
                proxy_redirect  http://discourse.jonaharagon.com:25654/ https://discourse.jonaharagon.com;
Chrome on my laptop and phone are returning an ERR_SSL_PROTOCOL_ERROR and SSL Labs is telling me my site doesn’t even have a certificate. The two certificate files do exist, and this same type of configuration works perfectly on other servers of mine. I can’t think of any reason this shouldn’t work, but maybe I’m just being dumb. Nginx gives no errors and works fine, and I’ve tried everything I can think of, I even made the files and directories all with 777 permissions (this isn’t a production server, it’ll be down in a few days) and nothing.
Any idea?
Well, something is wrong indeed:
osiris@desktop ~ $ openssl s_client -connect discourse.jonaharagon.com:443 -servername discourse.jonaharagon.com
CONNECTED(00000003)
139865335457424:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:s23_clnt.c:795:
no peer certificate available
SSL handshake has read 7 bytes and written 342 bytes
New, (NONE), Cipher is (NONE)
Compression: NONE
Expansion: NONE
osiris@desktop ~ $ telnet discourse.jonaharagon.com 443
Trying 162.243.30.30...
Connected to discourse.jonaharagon.com.
Escape character is '^]'.
GET / HTTP/1.1
Host: discourse.jonaharagon.com
HTTP/1.1 200 OK
Server: nginx/1.4.6 (Ubuntu)
From the nginx docs:
To configure an HTTPS server, the ssl parameter must be enabled on listening sockets in the server block, and the locations of the server certificate and private key files should be specified:
    listen              443 ssl;
    server_name         www.example.com;
    ssl_certificate     www.example.com.crt;
    ssl_certificate_key www.example.com.key;
    ssl_protocols       TLSv1 TLSv1.1 TLSv1.2;
    ssl_ciphers         HIGH:!aNULL:!MD5;
So that's your problem. You've got to add ssl to the listen 443 part to enable TLS in the first place...
