ERR_SSL_PROTOCOL_ERROR with Nginx
Chrome on my laptop and phone are returning an ERR_SSL_PROTOCOL_ERROR and SSL Labs is telling me my site doesn’t even have a certificate.
What’s wrong with my configuration?
$ openssl s_client -connect bluma.net:443
CONNECTED(00000003)
write:errno=104
no peer certificate available
SSL handshake has read 0 bytes and written 176 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : 0000
    Session-ID:
    Session-ID-ctx:
    Master-Key:
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    Start Time: 1556822276
    Timeout   : 7200 (sec)
    Verify return code: 0 (ok)
    Extended master secret: no
And the site configuration:
    listen 443 ssl;
    listen [::]:443 ssl;
    server_name bluma.net;
    root   /var/www/domains/bluma.net;
    access_log  /var/log/nginx/bluma.net.access.log;
    error_log /var/log/nginx/bluma.net.error.log;
    include /etc/nginx/sites-available/include-php;
        if (!-e $request_filename) {
            rewrite ^/(.*) /index.php?q=$1;
    ssl on;
    ssl_certificate /etc/letsencrypt/live/bluma.net/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/bluma.net/privkey.pem; # managed by Certbot
    ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
    ssl_ciphers EECDH+CHACHA20:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
    ssl_prefer_server_ciphers on;
    #ssl_session_tickets off;
The only thing I can think is that your not forwarding port 443 correctly in to your server.
Hi @bluemanos
there are some curious things. Your ip addresses ( https://check-your-website.server-daten.de/?q=bluma.net ):
bluma.net A 51.77.59.50 yes 1 0
AAAA yes
www.bluma.net A 104.28.4.73 yes 1 0
A 104.28.5.73 yes 1 0
AAAA 2606:4700:30::681c:449 yes
AAAA 2606:4700:30::681c:549 yes
And there are redirects https -> http:
• http://bluma.net/
51.77.59.50 200 0.080 H
• http://www.bluma.net/
104.28.4.73 200 0.097 H
104.28.5.73 200 0.094 H
2606:4700:30::681c:449 200 0.097 H
2606:4700:30::681c:549 200 0.094 H
• https://www.bluma.net/
104.28.4.73 301 http://www.bluma.net/ 0.173 F
104.28.5.73 301 http://www.bluma.net/ 0.170 F
2606:4700:30::681c:449 301 http://www.bluma.net/ 0.150 F
2606:4700:30::681c:549 301 http://www.bluma.net/ 0.157 F
• https://bluma.net/
51.77.59.50 -4 0.144 W
SendFailure - The underlying connection was closed: An unexpected error occurred on a send. Authentication failed because the remote party has closed the transport stream.
A lot of Grade F.
One - https + non-www - doesn't work. The other - redirect https -> http.
You are right - I fixed this. Unfortunately still the domain is not working :confused:
What says
nginx -t
Check the nginx logs.
nginx -t is and was ok.
Finally, I figured it out what was wrong with the configuration.
Nginx (my version: nginx/1.14.0) needs a one default_server in listen entry also for port 443. I added it to the domain listen 443 default_server ssl;. And after this the domain is working correctly. Hopeful other domains will also works.
Now your configuration works.
There is a new check ( https://check-your-website.server-daten.de/?q=bluma.net ):
You use a certificate with only one domain name:
CN=bluma.net
	03.05.2019
	01.08.2019
expires in 90 days	bluma.net - 1 entry
But you have two dns entries. So create one certificate with both domain names and use that.
