Need help with certbot
Understood.
But we are also just volunteers here.
We are not on 24/7 support to this forum; we provide support when we can throughout the day.
this i found from acces log
213.90.6.169 - - [01/Sep/2021:12:55:58 +0200] "GET /.well-known/acme-challenge/Test-File-1234 HTTP/1.1" 404 9331 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:91.0) Gecko/20100101 Firefox/91.0"
code what i paste in httpd.conf:
# Deny access to the entirety of your server's filesystem. You must
# explicitly permit access to web content directories in other
# <Directory> blocks below.
<Directory c:/acme-challenges>
 Options FollowSymLinks Includes
 AllowOverride None
 Require all granted
</Directory>
<IfModule alias_module>
 Alias /.well-known/acme-challenges/ c:/acme-challenges/
</IfModule>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
I see 404 in the access.log.
Is there anything in the error.log file?
Error log
[Tue Aug 31 21:20:01.419126 2021] [ssl:warn] [pid 6460:tid 576] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:20:01.475139 2021] [ssl:warn] [pid 6460:tid 576] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:20:01.523151 2021] [mpm_winnt:notice] [pid 6460:tid 576] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Tue Aug 31 21:20:01.523151 2021] [mpm_winnt:notice] [pid 6460:tid 576] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Tue Aug 31 21:20:01.523151 2021] [core:notice] [pid 6460:tid 576] AH00094: Command line: 'C:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Tue Aug 31 21:20:01.543155 2021] [mpm_winnt:notice] [pid 6460:tid 576] AH00418: Parent: Created child process 6660
[Tue Aug 31 21:20:02.135290 2021] [ssl:warn] [pid 6660:tid 504] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:20:02.199303 2021] [ssl:warn] [pid 6660:tid 504] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:20:02.263316 2021] [mpm_winnt:notice] [pid 6660:tid 504] AH00354: Child: Starting 150 worker threads.
[Tue Aug 31 21:25:42.705472 2021] [ssl:warn] [pid 10108:tid 584] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:25:42.760903 2021] [ssl:warn] [pid 10108:tid 584] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:25:42.790077 2021] [mpm_winnt:notice] [pid 10108:tid 584] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Tue Aug 31 21:25:42.790077 2021] [mpm_winnt:notice] [pid 10108:tid 584] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Tue Aug 31 21:25:42.790077 2021] [core:notice] [pid 10108:tid 584] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Tue Aug 31 21:25:42.805710 2021] [mpm_winnt:notice] [pid 10108:tid 584] AH00418: Parent: Created child process 2824
[Tue Aug 31 21:25:43.263321 2021] [ssl:warn] [pid 2824:tid 612] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:25:43.310210 2021] [ssl:warn] [pid 2824:tid 612] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:25:43.341903 2021] [mpm_winnt:notice] [pid 2824:tid 612] AH00354: Child: Starting 150 worker threads.
[Tue Aug 31 21:36:36.895740 2021] [ssl:warn] [pid 2440:tid 616] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:36:36.950247 2021] [core:warn] [pid 2440:tid 616] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Aug 31 21:36:36.950247 2021] [ssl:warn] [pid 2440:tid 616] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:36:36.980387 2021] [mpm_winnt:notice] [pid 2440:tid 616] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Tue Aug 31 21:36:36.980387 2021] [mpm_winnt:notice] [pid 2440:tid 616] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Tue Aug 31 21:36:36.980387 2021] [core:notice] [pid 2440:tid 616] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Tue Aug 31 21:36:36.980387 2021] [mpm_winnt:notice] [pid 2440:tid 616] AH00418: Parent: Created child process 4544
[Tue Aug 31 21:36:37.450630 2021] [ssl:warn] [pid 4544:tid 612] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:36:37.497520 2021] [ssl:warn] [pid 4544:tid 612] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 21:36:37.527161 2021] [mpm_winnt:notice] [pid 4544:tid 612] AH00354: Child: Starting 150 worker threads.
[Tue Aug 31 22:08:09.747096 2021] [autoindex:error] [pid 4544:tid 1852] [client 127.0.0.1:50809] AH01276: Cannot serve directory C:/xampp/phpMyAdmin/: No matching DirectoryIndex (index.php,index.pl,index.cgi,index.asp,index.shtml,index.html,index.htm,default.php,default.pl,default.cgi,default.asp,default.shtml,default.html,default.htm,home.php,home.pl,home.cgi,home.asp,home.shtml,home.html,home.htm) found, and server-generated directory index forbidden by Options directive
[Tue Aug 31 22:11:14.115136 2021] [ssl:warn] [pid 6720:tid 608] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 22:11:14.168537 2021] [core:warn] [pid 6720:tid 608] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Aug 31 22:11:14.168537 2021] [ssl:warn] [pid 6720:tid 608] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 22:11:14.215431 2021] [mpm_winnt:notice] [pid 6720:tid 608] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Tue Aug 31 22:11:14.215431 2021] [mpm_winnt:notice] [pid 6720:tid 608] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Tue Aug 31 22:11:14.215431 2021] [core:notice] [pid 6720:tid 608] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Tue Aug 31 22:11:14.215431 2021] [mpm_winnt:notice] [pid 6720:tid 608] AH00418: Parent: Created child process 5304
[Tue Aug 31 22:11:14.821706 2021] [ssl:warn] [pid 5304:tid 596] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 22:11:14.868592 2021] [ssl:warn] [pid 5304:tid 596] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Tue Aug 31 22:11:14.906368 2021] [mpm_winnt:notice] [pid 5304:tid 596] AH00354: Child: Starting 150 worker threads.
[Tue Aug 31 23:15:26.349268 2021] [authz_core:error] [pid 5304:tid 1808] [client 199.19.224.165:59716] AH01630: client denied by server configuration: C:/xampp/htdocs/config/getuser
[Wed Sep 01 02:18:40.212570 2021] [authz_core:error] [pid 5304:tid 1804] [client 199.19.224.165:53690] AH01630: client denied by server configuration: C:/xampp/htdocs/config/getuser
[Wed Sep 01 08:53:39.062264 2021] [authz_core:error] [pid 5304:tid 1840] [client 199.19.224.165:53554] AH01630: client denied by server configuration: C:/xampp/htdocs/config/getuser
[Wed Sep 01 09:35:34.739812 2021] [ssl:warn] [pid 656:tid 620] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:35:34.791799 2021] [core:warn] [pid 656:tid 620] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Sep 01 09:35:34.795803 2021] [ssl:warn] [pid 656:tid 620] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:35:34.836821 2021] [mpm_winnt:notice] [pid 656:tid 620] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Wed Sep 01 09:35:34.836821 2021] [mpm_winnt:notice] [pid 656:tid 620] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Wed Sep 01 09:35:34.836821 2021] [core:notice] [pid 656:tid 620] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Wed Sep 01 09:35:34.841817 2021] [mpm_winnt:notice] [pid 656:tid 620] AH00418: Parent: Created child process 4724
[Wed Sep 01 09:35:35.387870 2021] [ssl:warn] [pid 4724:tid 192] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:35:35.439852 2021] [ssl:warn] [pid 4724:tid 192] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:35:35.473851 2021] [mpm_winnt:notice] [pid 4724:tid 192] AH00354: Child: Starting 150 worker threads.
[Wed Sep 01 09:36:51.004519 2021] [authz_core:error] [pid 4724:tid 1804] [client 213.90.6.169:39032] AH01630: client denied by server configuration: C:/acme-challenge/Test-File-1234
[Wed Sep 01 09:36:52.828960 2021] [authz_core:error] [pid 4724:tid 1788] [client 195.202.130.6:60864] AH01630: client denied by server configuration: C:/acme-challenge/Test-File-1234, referer: https://www.google.com/
[Wed Sep 01 09:39:33.105365 2021] [ssl:warn] [pid 3872:tid 608] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:39:33.158364 2021] [core:warn] [pid 3872:tid 608] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Sep 01 09:39:33.163349 2021] [ssl:warn] [pid 3872:tid 608] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:39:33.193368 2021] [mpm_winnt:notice] [pid 3872:tid 608] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Wed Sep 01 09:39:33.193368 2021] [mpm_winnt:notice] [pid 3872:tid 608] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Wed Sep 01 09:39:33.193368 2021] [core:notice] [pid 3872:tid 608] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Wed Sep 01 09:39:33.198370 2021] [mpm_winnt:notice] [pid 3872:tid 608] AH00418: Parent: Created child process 5532
[Wed Sep 01 09:39:33.693407 2021] [ssl:warn] [pid 5532:tid 624] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:39:33.737409 2021] [ssl:warn] [pid 5532:tid 624] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:39:33.767411 2021] [mpm_winnt:notice] [pid 5532:tid 624] AH00354: Child: Starting 150 worker threads.
[Wed Sep 01 09:43:52.956029 2021] [ssl:warn] [pid 9496:tid 588] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:43:53.017017 2021] [core:warn] [pid 9496:tid 588] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Sep 01 09:43:53.022019 2021] [ssl:warn] [pid 9496:tid 588] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:43:53.066017 2021] [mpm_winnt:notice] [pid 9496:tid 588] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Wed Sep 01 09:43:53.066017 2021] [mpm_winnt:notice] [pid 9496:tid 588] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Wed Sep 01 09:43:53.066017 2021] [core:notice] [pid 9496:tid 588] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Wed Sep 01 09:43:53.072018 2021] [mpm_winnt:notice] [pid 9496:tid 588] AH00418: Parent: Created child process 4776
[Wed Sep 01 09:43:53.671082 2021] [ssl:warn] [pid 4776:tid 596] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:43:53.731089 2021] [ssl:warn] [pid 4776:tid 596] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:43:53.770086 2021] [mpm_winnt:notice] [pid 4776:tid 596] AH00354: Child: Starting 150 worker threads.
[Wed Sep 01 09:47:33.910021 2021] [ssl:warn] [pid 7440:tid 620] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:47:33.970029 2021] [core:warn] [pid 7440:tid 620] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Sep 01 09:47:33.975030 2021] [ssl:warn] [pid 7440:tid 620] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:47:34.009048 2021] [mpm_winnt:notice] [pid 7440:tid 620] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Wed Sep 01 09:47:34.009048 2021] [mpm_winnt:notice] [pid 7440:tid 620] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Wed Sep 01 09:47:34.009048 2021] [core:notice] [pid 7440:tid 620] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Wed Sep 01 09:47:34.015048 2021] [mpm_winnt:notice] [pid 7440:tid 620] AH00418: Parent: Created child process 7152
[Wed Sep 01 09:47:34.552082 2021] [ssl:warn] [pid 7152:tid 524] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:47:34.605092 2021] [ssl:warn] [pid 7152:tid 524] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:47:34.637077 2021] [mpm_winnt:notice] [pid 7152:tid 524] AH00354: Child: Starting 150 worker threads.
[Wed Sep 01 09:48:45.019230 2021] [ssl:warn] [pid 10676:tid 648] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:48:45.077218 2021] [core:warn] [pid 10676:tid 648] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Sep 01 09:48:45.081220 2021] [ssl:warn] [pid 10676:tid 648] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:48:45.116239 2021] [mpm_winnt:notice] [pid 10676:tid 648] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Wed Sep 01 09:48:45.116239 2021] [mpm_winnt:notice] [pid 10676:tid 648] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Wed Sep 01 09:48:45.116239 2021] [core:notice] [pid 10676:tid 648] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Wed Sep 01 09:48:45.122241 2021] [mpm_winnt:notice] [pid 10676:tid 648] AH00418: Parent: Created child process 4736
[Wed Sep 01 09:48:45.691264 2021] [ssl:warn] [pid 4736:tid 596] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:48:45.748268 2021] [ssl:warn] [pid 4736:tid 596] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:48:45.786272 2021] [mpm_winnt:notice] [pid 4736:tid 596] AH00354: Child: Starting 150 worker threads.
[Wed Sep 01 09:49:19.283516 2021] [ssl:warn] [pid 1512:tid 620] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:49:19.332518 2021] [core:warn] [pid 1512:tid 620] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Sep 01 09:49:19.335498 2021] [ssl:warn] [pid 1512:tid 620] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:49:19.372500 2021] [mpm_winnt:notice] [pid 1512:tid 620] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Wed Sep 01 09:49:19.372500 2021] [mpm_winnt:notice] [pid 1512:tid 620] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Wed Sep 01 09:49:19.372500 2021] [core:notice] [pid 1512:tid 620] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Wed Sep 01 09:49:19.378515 2021] [mpm_winnt:notice] [pid 1512:tid 620] AH00418: Parent: Created child process 9172
[Wed Sep 01 09:49:19.885554 2021] [ssl:warn] [pid 9172:tid 640] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:49:19.931556 2021] [ssl:warn] [pid 9172:tid 640] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:49:19.969545 2021] [mpm_winnt:notice] [pid 9172:tid 640] AH00354: Child: Starting 150 worker threads.
[Wed Sep 01 09:50:49.608185 2021] [ssl:warn] [pid 10180:tid 608] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:50:49.655189 2021] [core:warn] [pid 10180:tid 608] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Sep 01 09:50:49.658176 2021] [ssl:warn] [pid 10180:tid 608] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:50:49.688178 2021] [mpm_winnt:notice] [pid 10180:tid 608] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Wed Sep 01 09:50:49.688178 2021] [mpm_winnt:notice] [pid 10180:tid 608] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Wed Sep 01 09:50:49.688178 2021] [core:notice] [pid 10180:tid 608] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Wed Sep 01 09:50:49.693177 2021] [mpm_winnt:notice] [pid 10180:tid 608] AH00418: Parent: Created child process 6608
[Wed Sep 01 09:50:50.175230 2021] [ssl:warn] [pid 6608:tid 624] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:50:50.227242 2021] [ssl:warn] [pid 6608:tid 624] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:50:50.266221 2021] [mpm_winnt:notice] [pid 6608:tid 624] AH00354: Child: Starting 150 worker threads.
[Wed Sep 01 09:52:27.427309 2021] [mpm_winnt:crit] [pid 6608:tid 624] AH02538: Child: Parent process exited abruptly. Child process is ending
[Wed Sep 01 09:52:30.342744 2021] [ssl:warn] [pid 8008:tid 692] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:52:30.394751 2021] [core:warn] [pid 8008:tid 692] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Sep 01 09:52:30.398762 2021] [ssl:warn] [pid 8008:tid 692] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:52:30.431751 2021] [mpm_winnt:notice] [pid 8008:tid 692] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Wed Sep 01 09:52:30.431751 2021] [mpm_winnt:notice] [pid 8008:tid 692] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Wed Sep 01 09:52:30.431751 2021] [core:notice] [pid 8008:tid 692] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Wed Sep 01 09:52:30.437757 2021] [mpm_winnt:notice] [pid 8008:tid 692] AH00418: Parent: Created child process 10656
[Wed Sep 01 09:52:31.006811 2021] [ssl:warn] [pid 10656:tid 512] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:52:31.053798 2021] [ssl:warn] [pid 10656:tid 512] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:52:31.082805 2021] [mpm_winnt:notice] [pid 10656:tid 512] AH00354: Child: Starting 150 worker threads.
[Wed Sep 01 09:59:42.504499 2021] [mpm_winnt:crit] [pid 10656:tid 512] AH02538: Child: Parent process exited abruptly. Child process is ending
[Wed Sep 01 09:59:45.418060 2021] [ssl:warn] [pid 3316:tid 596] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:59:45.468066 2021] [core:warn] [pid 3316:tid 596] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Sep 01 09:59:45.472053 2021] [ssl:warn] [pid 3316:tid 596] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:59:45.499053 2021] [mpm_winnt:notice] [pid 3316:tid 596] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Wed Sep 01 09:59:45.499053 2021] [mpm_winnt:notice] [pid 3316:tid 596] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Wed Sep 01 09:59:45.499053 2021] [core:notice] [pid 3316:tid 596] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Wed Sep 01 09:59:45.505054 2021] [mpm_winnt:notice] [pid 3316:tid 596] AH00418: Parent: Created child process 10356
[Wed Sep 01 09:59:46.097112 2021] [ssl:warn] [pid 10356:tid 532] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:59:46.147103 2021] [ssl:warn] [pid 10356:tid 532] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 09:59:46.180105 2021] [mpm_winnt:notice] [pid 10356:tid 532] AH00354: Child: Starting 150 worker threads.
[Wed Sep 01 12:54:10.812891 2021] [ssl:warn] [pid 800:tid 648] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 12:54:10.861897 2021] [core:warn] [pid 800:tid 648] AH00098: pid file C:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Sep 01 12:54:10.866899 2021] [ssl:warn] [pid 800:tid 648] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 12:54:10.901900 2021] [mpm_winnt:notice] [pid 800:tid 648] AH00455: Apache/2.4.48 (Win64) OpenSSL/1.1.1k PHP/8.0.9 configured -- resuming normal operations
[Wed Sep 01 12:54:10.901900 2021] [mpm_winnt:notice] [pid 800:tid 648] AH00456: Apache Lounge VS16 Server built: May 18 2021 10:45:56
[Wed Sep 01 12:54:10.901900 2021] [core:notice] [pid 800:tid 648] AH00094: Command line: 'c:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Wed Sep 01 12:54:10.906922 2021] [mpm_winnt:notice] [pid 800:tid 648] AH00418: Parent: Created child process 10700
[Wed Sep 01 12:54:11.514966 2021] [ssl:warn] [pid 10700:tid 604] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 12:54:11.572948 2021] [ssl:warn] [pid 10700:tid 604] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Wed Sep 01 12:54:11.613954 2021] [mpm_winnt:notice] [pid 10700:tid 604] AH00354: Child: Starting 150 worker threads.
[Wed Sep 01 13:31:35.073389 2021] [authz_core:error] [pid 10700:tid 1836] [client 199.19.224.165:43714] AH01630: client denied by server configuration: C:/xampp/htdocs/config/getuser
[Wed Sep 01 16:46:41.041551 2021] [authz_core:error] [pid 10700:tid 1844] [client 199.19.224.165:53756] AH01630: client denied by server configuration: C:/xampp/htdocs/config/getuser
Acess log:
Please show the vhost config file.
# Virtual Hosts
# Required modules: mod_log_config
# If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them. Most configurations
# use only name-based virtual hosts so the server doesn't need to worry about
# IP addresses. This is indicated by the asterisks in the directives below.
# Please see the documentation at
# <URL:http://httpd.apache.org/docs/2.4/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
# Use name-based virtual hosting.
##NameVirtualHost *:80
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
# The first VirtualHost section is used for all requests that do not
# match a ##ServerName or ##ServerAlias in any <VirtualHost> block.
##<VirtualHost *:80>
    ##ServerAdmin webmaster@dummy-host.example.com
    ##DocumentRoot "C:/xampp/htdocs/dummy-host.example.com"
    ##ServerName dummy-host.example.com
    ##ServerAlias www.dummy-host.example.com
    ##ErrorLog "logs/dummy-host.example.com-error.log"
    ##CustomLog "logs/dummy-host.example.com-access.log" common
##</VirtualHost>
    ##ServerAdmin webmaster@dummy-host2.example.com
    ##DocumentRoot "C:/xampp/htdocs/dummy-host2.example.com"
    ##ServerName dummy-host2.example.com
    ##ErrorLog "logs/dummy-host2.example.com-error.log"
    ##CustomLog "logs/dummy-host2.example.com-access.log" common
##</VirtualHost>
The entire post is commented out.
Where is the in use vhost for port 80?
Here my friend I cannot answer to you...
Im not a programmer...
This must configure myself or?
Well you are doing things programmers do.
You will need a functional HTTP site before you can secure it (via HTTP authentication).
Or put in another way:
Why do you need to secure a site you don't even have?
Can you please help me edit this?
Or shut down everything and go to sleep? :rofl:
But first have a :beer: or four :slight_smile:
neah i want to solve this...
Then you need to learn how to serve an HTTP web site.
[that is not something we teach here]
ok, thanks for your time!
For the server certificate does NOT include an ID which matches the server name, here's a 3-step procedure to change the existing host from ServerName www.example.com:443 to ServerName localhost
Note that when you shut down Apache, you should wait until all processes have stopped before restarting. You can do a lot with the xampp control panel. :wink:
I did it myself, xampp comes with ssl preconfigured, you just need to edit certificate files with notepad from conf folder. and redirect port 80 to 443.
http://sabforum.ddns.net
https://sabforum.ddns.net/index.php
Which cert file did you use?
[cert.pem or fullchain.pem]
