Need help renewing a certificate
My domain is: JRG.ubrandvip.app
bh.ubrandvip.app
evh.ubrandvip.app
I ran this command: No command done, need help to do this
My web server is (include version): not sure
The operating system my web server runs on is (include version): not sure
My hosting provider, if applicable, is: Oracle
I can login to a root shell on my machine (yes or no, or I don't know): I think so
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): not sure
I see from the public log history you recently got certs for these domain names. They are individual certs for each name.
But, HTTPS requests to your domains do not use their most recent cert and so show an Expired error.
After getting a cert you need to make sure your service is using it. It looks like you have not done that.
We would need more details from you to help you with that. Although, configuring your server and services is something you should know how to do anyway.
I have access to Oracle Cloud where things reside, but I do not know how to navigate or renew.
Can you help?
Are there any scheduled jobs [that might provide insight on which ACME client is in use]?
The primary support for ACME is: Self-Service
We are here [as volunteers] to help primarily with technical issues.
