Need help instaling apache ubuntu 14.04
My domain is:billyiks.com
I ran this command:./certbot-auto
It produced this output: Domain: billyiks.com
Type: connection
Detail: Failed to connect to 184.168.221.22:443 for TLS-SNI-01
challenge
My operating system is (include version):14.04
My hosting provider, if applicable, is:godady re directer to another ip
How are you redirecting things ? I suspect that's the cause of your issue.
Try
./certbot-auto --preferred-challenges http-01
to use the http challenge which will redirect better in your case I suspect.
root@Cobra:~# chmod a+x certbot-auto
root@Cobra:~# /certbot-auto --preferred-challenges http-01
-bash: /certbot-auto: No such file or directory
root@Cobra:~# ./certbot-auto
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter 'c' to cancel):billyiks.com
Enter email address (used for urgent renewal and security notices) (Enter 'c' to
cancel):cobra.tv@yahoo.com
https://letsencrypt.org/documents/LE-SA-v1.1.1-August-1-2016.pdf. You must agree
in order to register with the ACME server at
https://acme-v01.api.letsencrypt.org/directory
(A)gree/(C)ancel: a
tls-sni-01 challenge for billyiks.com
Failed authorization procedure. billyiks.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 184.168.221.22:443 for TLS-SNI-01 challenge
  • If you lose your account credentials, you can recover through
    e-mails sent to cobra.tv@yahoo.com.
    Type: connection
    challenge
  • Your account credentials have been saved in your Certbot
    root@Cobra:~#
this what i gave me
You missed the initial period off the command
Note: it starts with a period - this means it triest to run the command (certbot-auto) in the current folder.
(A)gree/(C)ancel: a
    Type: connection
    challenge
    root@Cobra:~#
    root@Cobra:~#
    root@Cobra:~#
    root@Cobra:~#
    root@Cobra:~#
    root@Cobra:~# ./certbot-auto --preferred-challenges http-01
    None of the preferred challenges are supported by the selected plugin
    root@Cobra:~#
    nothing worked
how can i open port 443 might be that
this is the steps im using
can you give another step to see whats wrong
Have you got a firewall that's blocking port 443 ?
If not then running
sudo a2enmod ssl
and
sudo service apache2 restart
should enable https on ubuntu.
no it did not work
can you check by TeamViewer my server ??
Is certbot still giving the same error when run ?
yes is still the same
