Issues Setting up LetsEncrypt with Cryptbot for Apache
My domain is: triverticy.com
I ran this command: certbot --apache
I also ran this command: certbot renew --dry-run --force-renewal
Failed authorization procedure. triverticy.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 71.47.82.86:443 for TLS-SNI-01 challenge
   Domain: triverticy.com
   Type:   connection
   Detail: Failed to connect to 71.47.82.86:443 for TLS-SNI-01
   challenge
The second command produced this output:
No renewals were attempted.
**          (The test certificates above have not been saved.)
Ubuntu 16.10
Apache 2.4.18
Yes
Not yet
I apologize if this is a duplicate of other threads. I have been trying to find a solution to my problem. I have LAMP setup and configured proerly and am attempting to get a certificate for HTTPS before continuing. I have attempted several command and tried to configure the ServerName for apache but still nothing. I have also ensured that port 443 is open on my network. The logs that LetsEncrypt creates are as follows:
2016-12-31 21:01:22,834:DEBUG:certbot.main:Root logging level set at 30
2016-12-31 21:01:22,835:INFO:certbot.main:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2016-12-31 21:01:22,835:DEBUG:certbot.main:certbot version: 0.8.1
2016-12-31 21:01:22,835:DEBUG:certbot.main:Arguments: ['--dry-run', '--force-renewal']
2016-12-31 21:01:22,836:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#webroot,PluginEntryPoint#nu$
2016-12-31 21:01:22,837:DEBUG:certbot.renewal:no renewal failures
I also had a more extensive log from a previous attempt to set up Certbot that contained the error message that I am now getting. (In the older attempt the setup completed with just the command “sudo certbot” now it gives the error above.)
try using a DNS challenge of HTTP challenge
which requires a DNS entry or a file to be put on the web server
Do you have Apache listening on port 443? It could be blocking certbot from working. If you don’t want to take that down for every renewal, you could look into the webroot method or use the DNS challenge method.
