Hello. I tried to install on Namecheap. I have 3 sites on there, and the site I tried to install the files on is not the main account, so there is not public_html for it. I am not a programmer, so I do not know where else this can be put.
I tried to install on my main domain and there was already a folder named well known with a folder under it, so I just added the folder/files from LE, but got an error stating that LE is not comparable.
I wrote to NC’s SSL support and they seem willing to help, this was their response:
Hello Tamie,
Thank you for contacting us.
Unfortunately, we cannot help you with the issuance of the Let’s Encrypt SSL certificate as that is a third-party product.
However, we will be able to help you with the installation when you get the certificate issued.
Please keep in mind that you will need the Certificate code and private key.
Private key is an encoded piece of data, usually a few dozen lines of randomly looking symbols, enclosed with the headers similar to these ones: -----BEGIN RSA PRIVATE KEY----- and -----END RSA PRIVATE KEY-----
Those will be provided after you pass the validation of the certificate on their side.
Feel free to contact us again in case of any questions or issues.
Then share your environment. If you don’t have root access (if you use shared hosting), your options may be limited. Or it may be impossible to use Letsencrypt certificates.
Have you considered the script acme.sh if you have shell access?
If not, then like @JuergenAuer said, your options are extremely limited and inconvenient.
If my memory served right, Namecheap hosting does allow you to use acme.sh and shell access, so you could issue your certificates automatically and without any renewal issue.
If you need help requesting and installing the certificate with acme.sh, please post your reply here.
Thank you both. I have to get a response from NameCheap and they have been having “connectivity issues,” so I haven’t been able to speak with the SSL people.
I am wondering if you know whether I should use a wordpress plugin such as SSL Zen once this is setup or will the shell thing take care of that?
Once I get some answers from NC I will come back and give you guys the info.
You don't need to speak to their SSL people since most hosting providers aren't willing to help set up a third party certificate when they sell for themselves.
I believe the shell approach is pretty straight forward, so it should be easy to setup...
If you've setup shell program and the certificate had been updated, you should be good to go. (Unless there's mixed-content error)
I have 3 sites, but the 2 I was working on are hpriestess.comunionofsolitaries.com. Neither are published yet. I am using wordpress. As mentioned, the folder I was instructed to create under public_html for hpriestess.com already existed, so I added the the files LC provided, but got a page back in WP that said that LC was not comparable. I got nothing when I tried to do it for unionofsolitares because there was no public_html folder for that domain since it is not my main website, though it is not a subdomain, so I don’t know what it is considered.
My web server is (include version): Apache: 2.4
The operating system my web server runs on is (include version): CloudLinux Server release 6.6 (5.11 on servers 1-33)
My hosting provider, if applicable, is: Namecheap
I can login to a root shell on my machine (yes or no, or I don’t know): root access is not available
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): cPanel: 11.78
