http://www.billion.com
can not use ssl, i need help
thanks
thanks
FATAL
A fatal issue occurred during the DNS lookup process for billion.com/CAA.
DNS response for billion.com/CAA did not have an acceptable response code: SERVFAIL
i need help for my website in duda
If you require help, you'll need to fill in the whole questionnaire I posted earlier! Not just brief snaps of the process, we need all information.
Hi @angelcheng
your name servers are completely buggy.
There are older checks - one and 1,5 hours old - https://check-your-website.server-daten.de/?q=billion.com
There your name servers are ok, they answer.
| Domain | Nameserver | NS-IP |
| billion.com | • vdns1.digitalunited.com | 61.20.46.203 |
| Jian'an/Taipei/Taiwan (TW) - Far EastTone Telecommunication Co., Ltd. | • | |
| • vdns2.digitalunited.com | 61.20.46.204 | |
But checking from my pc:
dig CAA billion.com. @61.20.46.203
dig CAA billion.com. @61.20.46.204
Timeouts. Same with unboundtest - https://unboundtest.com/m/CAA/billion.com/KGXYQ5U2
Query results for CAA billion.com
----- Unbound logs -----
May 30 16:27:48 unbound[1049:0] notice: init module 0: validator
May 30 16:27:48 unbound[1049:0] notice: init module 1: iterator
May 30 16:27:48 unbound[1049:0] info: start of service (unbound 1.10.1).
May 30 16:27:49 unbound[1049:0] info: 127.0.0.1 billion.com. CAA IN
May 30 16:27:49 unbound[1049:0] info: resolving billion.com. CAA IN
May 30 16:27:49 unbound[1049:0] info: priming . IN NS
May 30 16:27:49 unbound[1049:0] info: response for . NS IN
May 30 16:27:49 unbound[1049:0] info: reply from <.> 2001:500:2f::f#53
May 30 16:27:49 unbound[1049:0] info: query response was ANSWER
May 30 16:27:49 unbound[1049:0] info: priming successful for . NS IN
May 30 16:27:49 unbound[1049:0] info: response for billion.com. CAA IN
May 30 16:27:49 unbound[1049:0] info: query response was REFERRAL
May 30 16:27:50 unbound[1049:0] info: response for billion.com. CAA IN
May 30 16:27:50 unbound[1049:0] info: reply from <com.> 2001:503:231d::2:30#53
May 30 16:27:50 unbound[1049:0] info: query response was REFERRAL
May 30 16:27:50 unbound[1049:0] info: resolving vdns2.digitalunited.com. AAAA IN
May 30 16:27:50 unbound[1049:0] info: priming . IN NS
May 30 16:27:50 unbound[1049:0] info: resolving vdns1.digitalunited.com. AAAA IN
May 30 16:27:50 unbound[1049:0] info: response for . NS IN
May 30 16:27:50 unbound[1049:0] info: reply from <.> 192.58.128.30#53
May 30 16:27:50 unbound[1049:0] info: query response was ANSWER
May 30 16:27:50 unbound[1049:0] info: priming successful for . NS IN
May 30 16:27:50 unbound[1049:0] info: response for vdns2.digitalunited.com. AAAA IN
May 30 16:27:50 unbound[1049:0] info: reply from <.> 192.203.230.10#53
May 30 16:27:50 unbound[1049:0] info: response for vdns1.digitalunited.com. AAAA IN
May 30 16:27:50 unbound[1049:0] info: reply from <.> 2001:7fd::1#53
May 30 16:27:50 unbound[1049:0] info: reply from <com.> 2001:502:8cc::30#53
May 30 16:27:50 unbound[1049:0] info: reply from <com.> 192.31.80.30#53
May 30 16:27:50 unbound[1049:0] info: reply from <digitalunited.com.> 61.20.46.203#53
May 30 16:27:51 unbound[1049:0] info: response for vdns2.digitalunited.com. AAAA IN
May 30 16:27:51 unbound[1049:0] info: reply from <digitalunited.com.> 61.20.46.204#53
May 30 16:27:51 unbound[1049:0] info: query response was nodata ANSWER
May 30 16:27:51 unbound[1049:0] info: response for vdns1.digitalunited.com. AAAA IN
May 30 16:27:53 unbound[1049:0] info: Capsforid: timeouts, starting fallback
Error running query: read udp 127.0.0.1:38168->127.0.0.1:1053: i/o timeout
So the online tool (from Berlin) can see your name servers. A pc from Berlin can't. Same Unboundtest / Letsencrypt.
can you tell me where online tool,i very need
and thanks your help
duda Provide how to use it,so have noCAA, so i do not standuand.
It’s not a problem of your configuration.
It’s a problem of your buggy name servers.
And you can’t fix it, because you don’t manage your name servers.
The owners of
have to do that.
Only thing you can do: Change your name servers.
But that may be impossible.
PS: Letsencrypt must check if there is a CAA record. If the name servers don’t answer or if they answer wrong (with a Servfail instead of NoData), Letsencrypt isn’t allowed to create a certificate. That’s a global rule.
thank your very much.
Donc, cette question peut s’appliquer pour SSL?
because duda give me the answer
Thanks for reaching out!
It seems like there are some links in this site that are not secured which are the reason the SSL failure. You can see an example here.​
Non-secure links or resources can cause the page to be flagged as non-secure, even if it has an SSL certificate. Things you need to make sure are secure are:
You can check to see if these things are secure by checking how they’re linked in your code. Secure external links begin with http s , while non-secure links begin with http . Local content that uses a relative path will automatically adopt SSL when it is installed on a domain.
How to fix
If you find any links that are http , you need to make them secure.
To fix unsecured links, you need to make sure that your HTML code either calls locally hosted elements via a relative path, such as:
/images.logo.png
/includes/script.js
Or, if they’re called by their absolute path, you need to be sure the link includes the http s .
https://mydomain.com/images/logo.png
https://mydomain.com/includes/script.js
Let us know if you have more questions.
