Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: www.clothestar.com
or certbot-auto --version
if you’re using Certbot):
Hi @Leo1rich
you have some older certificates ( https://check-your-website.server-daten.de/?q=clothestar.com ):
CRT-Id
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
1048649273
CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US
2018-12-22 03:01:25
2019-03-22 03:01:25
clothestar.com , www.clothestar.com
2 entries
1023325638
2018-12-12 05:38:31
2019-03-12 05:38:31
2 entries
1021261319
2018-12-11 11:59:45
2019-03-11 11:59:45
2 entries
1020284117
2018-12-11 04:52:00
2019-03-11 04:52:00
2 entries
1020206363
2018-12-11 04:08:54
2019-03-11 04:08:54
2 entries
You use one, that's 56 days expired:
CN=clothestar.com
22.12.2018
22.03.2019
56 days expired
clothestar.com, www.clothestar.com - 2 entries
How did you create these certificates?
Leo1rich:
Hi
How can I reconnect my site?
Thanks
It's impossible to find answers if you don't know how your system works.
The answers of the template are required.
Hi
Now is working
Is will block my site again?
Thanks
Hi
How I can extend certificates?
Thanks
It's impossible to answer if your configuration is unknown.
Certificates are immutable if they are created. So you create always a new certificate - perhaps with another set of domain names.
PS:
Leo1rich:
Now is working
Your https version doesn't work. The certificate ( https://check-your-website.server-daten.de/?q=clothestar.com )
CN=clothestar.com
22.12.2018
22.03.2019
60 days expired
is expired, there is no newer certificate. You redirect http -> https, but https has a timeout. So your site is invisible.
Hi
How do my site is visible?
So sorry about that I don’t know about that because I’m buy this site from flippa.com ,
Can you help me?
Thanks
system
closed
June 20, 2019, 10:06am
#11
