My SSL certificate will expire on October how to renew?
My domain is:www.rawansandart.com
I ran this command: My SSL certificate will expire on October how can I renew it before that date ?
My web server is (include version):Lightspeed 8.3.31
The operating system my web server runs on is (include version):Linux 4.18.0-553.54.1
My hosting provider, if applicable, is:The Constant Company, LLC.
I can login to a root shell on my machine (yes or no, or I don't know): I don’t know
get a new cert as you got old one in September. most client will renew itself at 2/3 or its lifetime so I'd start to worry if it was still using same old cert at 2026/09/20 or so.
Thank you , if it did not auto update after 20/9/2026 how to renew it?
Thanks
that certs are managed by quic.cloud CDN, so ask them.
Thank you very much
That timing is usually controlled by the ACME client or hosting panel rather than the certificate itself. Since the certificate is managed through the quic.cloud CDN, I would first check its renewal settings and whether the DNS/API credentials are still valid. If automatic renewal is not enabled, the provider should be able to trigger a replacement certificate before the current one expires. Have you checked the quic.cloud dashboard for the certificate's renewal status?
Thank you for your reply.
I did check and it’s auto renew .
Thanks for your help
Regards
