Ahh i see how can i fix this Certificate name mismatch for vvp.lerg.lt?
As it should; The only useable cert has other names on it:
so thats means i need to generate new certificate for this subdomain ![]()
Side note (not to derail the focus from @rg305 and @danb35 help):
Details on Apache can be found in documentation and forums:
The (simple) order is:
- HTTP site
- Certificate (using 1)
- HTTPS site (from 2)
NOT
- skip HTTP site
- HTTPS (via any cert)
- Certificate (manually)
so if i understand it right i need to remove rn cert for vvp.lerg.lt and generate new one ?
Actually, there is no substitute for knowledge.
Reading (even the man page / documentation) is better than tackling something new "unprepared".
So. your post is very relevant (and the best long-term solution to this and any such future problems).
You can leave it as is.
It just won't work (securely) until you get a real cert for it and use it.
Why it wont work can't i use free one for that also ?
The site will keep throwing security errors until you get (and use) a cert with that name on it.
That's what I meant by "won't work (securely)".
So thats means i need to buy 2 differen't certs or i can use 1 for both ?
Hello @Nelixus159123, welcome to the Let's Encrypt community. ![]()
Are you working with @Nolife159159 on the same set of domain names?
In general the first time someone post is a new Topic, but it seems you are working the www.lerg.lt, lerg.lt, and vvp.lerg.it issues. Two (or more) people one problem is fine.
Just trying to understand the audience I am communicating with.
Yeah im the same person just had to create new account cause @Nolife159159 got this
Thank you. ![]()
so i can't do something like this?
sudo certbot certonly --standalone -d lerg.lt -d www.lerg.lt -d vvp.lerg.lt
Yes.
But the certs are free.
So, you won't have to:
I would like to encourage @Nelixus159123 to carefully read both of these:
https://eff-certbot.readthedocs.io/en/stable/using.html#getting-certificates-and-choosing-plugins
... mainly in order to understand the differences between --manual, --standalone, and --apache in Certbot (and why one might choose to use each one).
What u mean by certs are free ?
Well somehow got it working
Let's Encrypt certs are free
