i'm using nginx in a raspberry pi, i have a local isp that uses port 80 as managment port, when anybody tries to connect to my trough that port nothing happens, i talked to them and they say i need to use other port, anyone know how to make the authentication with other port? i also tried "sudo certbot certonly --webroot" and i got an error saying:
Error creating new order :: too many failed authorizations recently: see Failed Validation Limit - Let's Encrypt
i am not sure what to do know, i tried apache and nginx and nginx is the furthest i've come. all guides that i used except let's encrypt where made trough chat GPT.
Hello @wirytiox, welcome to the Let's Encrypt community.
Only the HTTP-01 challenge of the Challenge Types - Let's Encrypt needs Port 80.
There are 2 other choices the DNS-01 challenge and the TLS-ALPN-01. Please read the Pros and Cons of each.
If you choose the DNS-01 challenge here is a list DNS providers who easily integrate with Let's Encrypt DNS validation
A list of some of the ACME Client Implementations - Let's Encrypt
There are other Free ACME CA Comparison - Posh-ACME
or certbot-auto --version
if you're using Certbot):
Thank you for assisting us in helping YOU!
The mod_md
module for Apache can take care of much of the certificate trouble for the Apache webserver all by itself, no external ACME client required. And it seems it can also do the tls-alpn-01
challenge, see its documentation here: GitHub - icing/mod_md: Let's Encrypt (ACME) in Apache httpd, GitHub - icing/mod_md: Let's Encrypt (ACME) in Apache httpd and GitHub - icing/mod_md: Let's Encrypt (ACME) in Apache httpd
