ISP blocks port 80
Hello there,
My ISP is blocking port 80.
Considering -preferred-challenges tls-sni is now disabled, I will not be able to authenticate with LE and subsequently easily renew unless port 80 is available?
Thanks,
Hi @Mukrosz,
Please see
for more information about your options. There are two other methods available in addition to HTTP-01. However, you won’t be able to use certbot --nginx or certbot --apache unless port 80 is available.
Thank you,
So basically my only option is DNS-01 challenge. Port 443 route is no longer available.
If you’re using Certbot, that’s right. If you want to consider using a different Let’s Encrypt client, lego and acme.sh (at least) have some level of support for TLS-ALPN-01 validation, which can still work over port 443. Certbot may support this method in the future, but implementing it isn’t currently scheduled.
Understood.
I’ll check the aforementioned projects. it will be difficult because of the very many years of certbot sentimental attachment :slight_smile:
Many thanks for your help!
Or: switch to another ISP.
For the most part, all ISPs do that for consumer level, at least where I live.
I’d need to upgrade to a business package and pay a lot more to have port 80 available to me.
Money grab, all it is.
Thanks again @schoen.
I got it to work with acme.sh using port 443
