My certificate is expired, I need to extend it
My website is stixex.io.
It is the main domain, it works fine.
But we have also subdomain: admin.stixex.io, it doesn't work
I think certificate is expired.
So I need to extend the valid date, please help me
Best regards
Our server is running on nginx (ubuntu),
certbot 1.7.0
root@ubuntu-2gb-hel1-3:/etc# nginx -t
When I try certbot renew, the results are following:
root@ubuntu-2gb-hel1-3:/etc# certbot renew
Processing /etc/letsencrypt/renewal/admin.stixex.io.conf
http-01 challenge for admin.stixex.io
Using the webroot path /var/www/letsencrypt for all unmatched domains.
Challenge failed for domain admin.stixex.io
Attempting to renew cert (admin.stixex.io) from /etc/letsencrypt/renewal/admin.stixex.io.conf produced an unexpected error: Some challenges have failed.. Skipping.
Processing /etc/letsencrypt/renewal/api.stixex.io.conf
http-01 challenge for api.stixex.io
Challenge failed for domain api.stixex.io
Attempting to renew cert (api.stixex.io) from /etc/letsencrypt/renewal/api.stixex.io.conf produced an unexpected error: Some challenges have failed.. Skipping.
Processing /etc/letsencrypt/renewal/stixex.io.conf
Cert not yet due for renewal
  /etc/letsencrypt/live/admin.stixex.io/fullchain.pem (failure)
  /etc/letsencrypt/live/api.stixex.io/fullchain.pem (failure)
  /etc/letsencrypt/live/stixex.io/fullchain.pem expires on 2021-08-05 (skipped)
2 renew failure(s), 0 parse failure(s)
   Domain: admin.stixex.io
   Type:   unauthorized
   Detail: Invalid response from
   http://admin.stixex.io/.well-known/acme-challenge/WvtUg6Hnq8n69T_Y5zImH91Nnpb1rZMO1I0ATIhoS40
   [135.181.144.36]: "<html>\r\n<head><title>404 Not
   Found</title></head>\r\n<body>\r\n<center><h1>404 Not
   Found</h1></center>\r\n<hr><center>nginx/1.18.0 (Ub"
   Domain: api.stixex.io
   Type:   unauthorized
   http://api.stixex.io/.well-known/acme-challenge/IHhuGtW9rAyACue3YwRA1_6zCJV05MpbsSHr7WzPx4Y
Indeed it is. So renew it. You've given us pretty much no information to go on, so whatever you did to get the cert in the first place, do it again.
Hello Danb35!
I just edited the description again, could you check it?
Hi @greatl-lancer,
I don't know how your webroot path got set to /var/www/letsencrypt but this is probably wrong—this is supposed to be set to the top-level content directory for each individual web site, so that Certbot can place files in it that appear directly at the top level of each web site. Do you have such a directory for each of these sites? If so, can you change the webroot path to the correct location for each domain?
I am the first for the letsencrypt.
Previous developer made this all, and it worked 2~3days ago.
I am not sure where I can change the webroot path.
Thanks
:frowning:
You can edit the individual text files in /etc/letsencrypt/renewal — there should be one for each certificate and they should have a webroot_path setting in them. If you edit that value, certbot renew will try to use the new value that you provide.
Yes I can find the "webroot_path" in the files, but I am not sure how I can find the top-level content directory for each individual web site.
Actually the directory : www/var/letsencrypto is empty
The webroot_path should be the directory of the website content(index.html)?
Yes, that's right. (There are still things that could make it not work, but that is normally what you should use.)
I've changed the webroot_path, but I still have the issues:
root@ubuntu-2gb-hel1-3:/etc# sudo certbot renew
Using the webroot path /home/ubuntu/admin_panel/dist for all unmatched domains.
Using the webroot path /home/ubuntu/stixex_backend/app for all unmatched domains.
   Type:   unauthorized
   http://admin.stixex.io/.well-known/acme-challenge/LrPd1wFG32xUHd3YxSZ1KIG7ZWwwPMmixIsBQIFNeLk
   Type:   unauthorized
   http://api.stixex.io/.well-known/acme-challenge/ZScE8oajFPaPS09zC3fS_21S7L8mbbGf85uqWCt1LL4
A further thing to try would be creating a file called test.txt in each of those directories, and seeing if you can then access it with http://api.stixex.io/test.txt (and the other one).
I just added the test.txt in the admin_panel.
but I can't access it
http://admin.stixex.io/test.txt
So, this makes me think that the directory that you specified is not the correct one for Certbot's purposes here.
(1) Can you find some other directory where the test.txt could be placed that would work?
(2) If not, would you be interested in trying other methods for Certbot to prove your control over the domain names that don't involve finding an existing directory from which static files are being served?
I've moved the file in the media folder, and I can see the file
http://admin.stixex.io/media/test.txt
Cool, what happens if you specify the media subdirectory in the webroot_path instead?
Yes I just specified the media subdirectory, but I have still same issue
http://admin.stixex.io/.well-known/acme-challenge/jU4Xe84F76ppY_JY7UYrDiRnlIh1g9IHkUIMeEG-33o
just to make sure you:
I just checked the static directory, but I can't see the ".well-known" directory
I'm concerned that there might be some rule defined in your nginx configuration to specifically serve this from a different location (distinct from the rest of your files). Could you try this?
fgrep -A 5 .well-known /etc/nginx
I just tried :
root@ubuntu-2gb-hel1-3:/etc/nginx/test# fgrep -A 5 .well-known /etc/nginx
grep: /etc/nginx: Is a directory
I'm sorry, I meant to add a -r, like
fgrep -r -A 5 .well-known /etc/nginx
