My certificate invalid and issued by not Let's Encrypt Authority X3
cargo-hemat.com
sudo certbot --apache (follow instruction from https://certbot.eff.org/lets-encrypt/centosrhel7-apache.html)
Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.3.15
CentOS 7.1 64-bit
domainesia
no
certbot 1.0.0
Helo,
First of all, i generate ssl for domain cargo-hemat.com in previous VPS and success.
and then i move this domain into another VPS, I was trying generate SSL this domain together with another domain (dev1.cargo-hemat.com). The domain dev1.cargo-hemat.com is success, but the domain cargo-hemat.com is invalid.
I give screenshot of this 2 domains, why the issuer of this 2 domain is different ?
I hope somebody can help my problems,
Thanks,
The first cert is only for the dev1 subdomain; as seen in the Subject Alternate Name field in the Details pane:
The second cert is a self-signed cert issued by the server for itself.
To better understand your current options, please show the output of:
certbot certificates
is this what you mean…
[root@cargo-hemat ~]# certbot certificates
Found the following certs:
Certificate Name: cargo-hemat.com-0001
Domains: cargo-hemat.com
Expiry Date: 2020-05-27 13:14:04+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/cargo-hemat.com-0001/fullchain.pem
Private Key Path: /etc/letsencrypt/live/cargo-hemat.com-0001/privkey.pem
Certificate Name: dev1.cargo-hemat.com
Domains: dev1.cargo-hemat.com
Expiry Date: 2020-05-27 05:55:24+00:00 (VALID: 88 days)
Certificate Path: /etc/letsencrypt/live/dev1.cargo-hemat.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/dev1.cargo-hemat.com/privkey.pem
I just revoke with this command :
[root@cargo-hemat ~]# certbot revoke --cert-path /etc/letsencrypt/live/cargo-hemat.com-0001/cert.pem --reason superseded
and certbot certificate become
After that im trying to generate new certificate…by command below
[root@cargo-hemat ~]# sudo certbot --apache
1: cargo-hemat.com
2: dev1.cargo-hemat.com
3: www.cargo-hemat.com
blank to select all options shown (Enter ‘c’ to cancel): 1
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: cargo-hemat.com: see https://letsencrypt.org/docs/rate-limits/
Is it means that i can issue new certificate next week ?
Don't. Unless the private key is compromised, revocation is always the wrong answer, and it won't have any effect on any rate limits.
(ignore this message)
Stop right now.
Are there lines saying # managed by certbot in any file in your /etc/apache/sites-enabled directory?
@dillahdoang, somewhere on your filesystem (in /etc/letsencrypt I dare say), unless you have deleted it, there is a valid certificate for the domains you need, issued yesterday: https://crt.sh/?q=cargo-hemat.com
You just need to install that.
The proper command should be
certbot --reinstall --apache -d cargo-hemat.com -d www.cargo-hemat.com -d dev1.cargo-hemat.com
The certs shown are unique and unrelated to each other - neither supersedes the other.
Deleting either would have been "wrong" enough.
You add insult to that injury by also revoking a perfectly good cert.
hi,
I follow you instruction, by doing this command..
[root@cargo-hemat ~]# certbot --duplicate --reinstall --apache -d cargo-hemat.com -d www.cargo-hemat.com -d dev1.cargo-hemat.com
Created an SSL vhost at /etc/httpd/sites-available/cargo-hemat.com-le-ssl.conf
Deploying Certificate to VirtualHost /etc/httpd/sites-available/cargo-hemat.com-le-ssl.conf
Enabling site /etc/httpd/sites-available/cargo-hemat.com-le-ssl.conf by adding Include to root configuration
Deploying Certificate to VirtualHost /etc/httpd/sites-available/dev1.cargo-hemat.com-le-ssl.conf
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Enhancement redirect was already set.
Congratulations! You have successfully enabled https://cargo-hemat.com,
https://www.cargo-hemat.com, and https://dev1.cargo-hemat.com
https://www.ssllabs.com/ssltest/analyze.html?d=cargo-hemat.com
https://www.ssllabs.com/ssltest/analyze.html?d=dev1.cargo-hemat.com
    /etc/letsencrypt/live/cargo-hemat.com/fullchain.pem
    /etc/letsencrypt/live/cargo-hemat.com/privkey.pem
    Your cert will expire on 2020-05-28. To obtain a new or tweaked
    with the "certonly" option. To non-interactively renew all of
  • Some rewrite rules copied from
    /etc/httpd/sites-enabled/cargo-hemat.com.conf were disabled in the
    vhost for your HTTPS site located at
    /etc/httpd/sites-available/cargo-hemat.com-le-ssl.conf because they
    have the potential to create redirection loops.
    Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
    Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
And after than when i test with url : SSL Server Test: cargo-hemat.com (Powered by Qualys SSL Labs)
its still like this
in subdomain dev1.cargo-hemat.com , the https works fine, and when i check the certification information in browser, this certification issued to cargo-hemat.com..it is different with the previous.
I try to compare the certification information in browser
this is in url https://cargo-hemat.com
this is in url https://dev1.cargo-hemat.com
CMIIW, I think domain cargo-hemat still not get the new certificate, based on date of "valid from.."
And I would like to ask, I have another subdomain in another server..is it gonna be a problem, since this certificate issued to main domain of cargo-hemat.com.
Thanks,
You need to check your VirtualHost blocks for cargo-hemat.com. It’s pulling a self-signed Certificate from your server (which usually means it’s routing to the default 443 vhost instead of the 443 vhost you have set up for cargo-hemat.com).
It also means it isn’t pulling the proper certificate, it would work just fine had it pulled both.
@dillahdoang, you need to check all the ServerName directives anywhere in /etc/httpd/sites-enabled . there should be one per file (or more). maybe some are in /etc/httpd/httpd.conf
Certbot says the cert is installed, so it’s apache now we’re debugging :smiley:
Reading on this, if you dont't have any other website hosted on that machine you can remove all other files from the sites-enabled directory. (you should probably use the a2dissite helper command)
In what file it is ?
I am using centos 7 , and based on my searching in google , there is no command "a2dissite". in centos.. CMIIW
When I see the content of folder /sites-enabled/ ..it contents of symbolic link from folder /sites-available/ ..
so, is it i have to make symbolic link for 2 file ssl.conf that exist ini sites-available..
but, the thing that make me confuse is without ssl.conf in sites-enabled, domain dev1.cargo-hemat.com still running ok.
i already create symbolic link for *ssl.conf … but its still not working :sob: :sob:
You do not need to create a symbolic link for the le-ssl.conf file. It is already linked as an include in the httpd.conf file. However if your server name reflects cargo-hemat.com it may be automatically routing to your default VirtualHost in /etc/httpd/conf.d/ssl.conf instead of the one that certbot made.
So how i can make it ..?
hi..
I can solved my problem with change content in ssl.conf with in conf that generate by certbot.
My reference is from this link :
Thanks,
The common way is to have, in sites-available, in a single file, both the http and https virtualhost, like this:
<VirtualHost *:80>
  ServerName example.com
  ServerName www.example.com
  # do stuff: serve unencrypted content, redirect, whatever
</VirtualHost>
<VirtualHost *:443>
  # do other stuff: serve encrypted content, etc etc
</VirtualHost>
I haven’t used apache in a long time though.
Then you symlink this file in sites-enabled and reload apache.
