Multi-level Wildcard Renewal is failing
My domain is: mountaintrips.com
[renewalparams]
account = 2b8838f9899d92d51a3f2ba91aa3dd0c
manual_public_ip_logging_ok = True
renew_hook = /etc/letsencrypt/renewal-hooks/deploy/deploy.sh
manual_auth_hook = /etc/letsencrypt/renewal-hooks/pre/authenticate.sh
authenticator = manual
pref_challs = dns-01,
“identifier”: {
“type”: “dns”,
“value”: “mountaintrips.com”
“status”: “invalid”,
“expires”: “2020-02-21T20:59:43Z”,
“challenges”: [
“type”: “dns-01”,
“error”: {
“type”: “urn:ietf:params:acme:error:unauthorized”,
“detail”: “Incorrect TXT record “h_O_dPHpTQIkmGgooCMDPsQ2Z16W5auV09GCRohIB4Q” found at _acme-challenge.mountaintrips.com”,
“status”: 403
“url”: “https://acme-v02.api.letsencrypt.org/acme/chall-v3/2818997906/glTonA”,
“token”: “78sHNSOTnPuUkXd_KmqICLlF9YRg9ICjtQLFZIB4Vo8”
“wildcard”: true
manual
CentOS Linux release 7.7.1908 (Core)
godaddy - dns, web - self-hosted
certbot 1.0.0
The original certificate requests authenticated successfully. When I went to run the renewals however, the validation failed. Here is the config:
renew_before_expiry = 30 days
version = 0.39.0
archive_dir = /etc/letsencrypt/archive/mountaintrips.com
cert = /etc/letsencrypt/live/mountaintrips.com/cert.pem
privkey = /etc/letsencrypt/live/mountaintrips.com/privkey.pem
chain = /etc/letsencrypt/live/mountaintrips.com/chain.pem
fullchain = /etc/letsencrypt/live/mountaintrips.com/fullchain.pem
[renewalparams]
when I did the original request, I used “-d mountaintrips.com -d *.mountaintrips.com” so that both the root and any subdomain would be in the certificate. I notice that certbot does 2 separate validations ( for each host specified,) but only one cert ultimately get’s created. The authenticate script I use is pretty basic. It does a callout to the godaddy API to update the TXT record:
DNS_REC_NAME="_acme-challenge"
DNS_REC_DATA="CERTBOT_VALIDATION" DNS_REC_TTL="600" ############################################################ curl -s -X PUT "{GODADDY_URL}/v1/domains/{CERTBOT_DOMAIN}/records/TXT/{DNS_REC_NAME}" -H “Accept: application/json” -H “Content-Type: application/json” -H “Authorization: sso-key {GODADDY_API_KEY}:{GODADDY_API_SECRET}” -d “[{ “data”: “{DNS_REC_DATA}\", \"name\": \"{DNS_REC_NAME}”, “ttl”: ${DNS_REC_TTL} }]”
Sleep for a bit to make sure the change has time to propagate
sleep 90
Anybody else running into this issue?
I think what’s happening is that the PUT API replaces all the TXT entries under _acme-challenge, so you’re wiping out your other challenge by accident.
So if the order of operations in Certbot is:
  1. Call auth hook for first _acme-challenge challenge
  2. Call auth hook for second _acme-challenge challenge
  3. Validate first challenge
  4. Validate second challenge
  5. Call cleanup hook for first _acme-challenge challenge
  6. Call cleanup hook for second _acme-challenge challenge
The API call in (2) essentially undoes the API call in (1), and then either (3) or (4) fails.
GoDaddy provides a PATCH version of that API call, which adds a record, rather than replacing all of the records matching the _acme-challenge label: https://developer.godaddy.com/doc/endpoint/domains#/v1/recordAdd
I think that should do what you want.
Also, check out acme.sh’s implementation of its GoDaddy DNS hook. It uses the PUT version, but it also includes all of the existing _acme-challenge TXT records in the PUT call, so earlier ones don’t get deleted.
Of course … you could just use acme.sh which supports GoDaddy natively without messing about with hooks: https://github.com/acmesh-official/acme.sh/wiki/dnsapi#4-use-godaddycom-domain-api-to-automatically-issue-cert
Thanks for the reply. Hmm. But how did it work for the initial certificate request which was successful? Problem is that the location of the _acme-challenge TXT record for *.domain.com and domain.com are in the same place. If I removed the -d domain.com then it would work but anyone browsing to the site without a host would get an SSL error. Is the order of operations different for the first cert vs renewal? I can’t use acme as I have other custom operations in a deploy.sh script that moves the certs to a load balancer.
I would guess that you fluked it by performing one of the authorizations on one run, and the other on another run.
Because authorizations on a single Let's Encrypt account get remembered/reused for some period of time between different orders, tricky issues like this one can get easily masked.
That's why since Certbot 0.40-ish, --dry-run deactivates all previous valid authorizations to prevent these kinds of false positive successes.
Yes. And that's the difference between PUT vs PATCH.
PUT sets the value of _acme-challenge to the values you provide in the PUT call.
PATCH adds the value you provide to the existing set of _acme-challenge values. So you would end up with both values under _acme-challenge.
From ACME perspective, there's no such thing as renewal. It's all the same.
I don't see why that would be a problem. acme.sh also allows you to have custom deploy hooks (as part of the acme.sh --install step).
Of course, it's your choice to keep using Certbot if you want - I believe the PUT/PATCH thing solves this for you.
To add some context, when Let’s Encrypt added wildcard support in the first place, heaps of custom hooks and clients had this precise issue, that they were incapable of creating multiple _acme-challenge TXT records against a single DNS label. So there was a lot of rewriting and bug fixing undertaken.
Unfortunately you hit the same pitfall :stuck_out_tongue: .
Ok, so are you saying I need to have multiple _acme-challenge records? I still do not understand how that would work. The LE DNS call would get a random response from GoDaddy in that scenario right? In my zone * is not a subdomain. Also, if you look at the logs, Certbot issues the same request for *.mountaintrips.com as mountaintrips.com. Both authorizations are “mountaintrips.com” - see logs below.
content-length: 487
cache-control: public, max-age=0, no-cache
strict-transport-security: max-age=604800
server: nginx
connection: keep-alive
link: https://acme-v02.api.letsencrypt.org/directory;rel=“index”
location: https://acme-v02.api.letsencrypt.org/acme/order/72222906/2332907212
boulder-requester: 72222906
date: Fri, 14 Feb 2020 20:59:43 GMT
x-frame-options: DENY
content-type: application/json
replay-nonce: 000119Ol7O15AVbr9zd2GkrZZSEJCOmBP3NUhpGSQVNC9u4
“status”: “pending”,
“expires”: “2020-02-21T20:59:43.880751746Z”,
“identifiers”: [
“type”: “dns”,
“value”: “*.mountaintrips.com”
“type”: “dns”,
“authorizations”: [
“https://acme-v02.api.letsencrypt.org/acme/authz-v3/2818997906”,
“https://acme-v02.api.letsencrypt.org/acme/authz-v3/2818997907”
“finalize”: “https://acme-v02.api.letsencrypt.org/acme/finalize/72222906/2332907212”
2020-02-14 12:59:43,929:DEBUG:acme.client:Storing nonce: 000119Ol7O15AVbr9zd2GkrZZSEJCOmBP3NUhpGSQVNC9u4
2020-02-14 12:59:43,930:DEBUG:acme.client:JWS payload:
2020-02-14 12:59:43,947:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/2818997906:
“protected”: “eyJub25jZSI6ICIwMDAxMTlPbDdPMTVBVmJyOXpkMkdrclpaU0VKQ09tQlAzTlVocEdTUVZOQzl1NCIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYXV0aHotdjMvMjgxODk5NzkwNiIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC83MjIyMjkwNiIsICJhbGciOiAiUlMyNTYifQ”,
“payload”: “”,
“signature”: “UODSTg0yIAmetwT_vSGuTda-0CrEfOeqJXeAstUbuyMhOYRsuUI3Y108iqM538UMFowmE1PWTarqbEll2iODysMsdEvbJqC6Hzct7gAvPafEs3VaqCDoX57vfXOZwDEpPrduwXPUmMrC3m3hrhc17y5YPcl3T2h7fiqIYo8WX3MlrOjr94hPCkD-_39dkar4FgrFv7c4aBqBeyjxIFFqFHe12blLafixo8-XDxvK0THqWFDlG6384qi7jWdF0nTma6vQasH71REqwuDsrc56SCgqu0GSDFguX0Rda5Vtbdl7uXm25SLicPrTVWT6k94Wh66H7dmdc9BagLoHfQ2M3w”
2020-02-14 12:59:44,002:DEBUG:urllib3.connectionpool:“POST /acme/authz-v3/2818997906 HTTP/1.1” 200 389
2020-02-14 12:59:44,003:DEBUG:acme.client:Received response:
HTTP 200
content-length: 389
server: nginx
replay-nonce: 0001IK4vVSJhXGnlA6_aNtx-bl7IByWPrA0lAFgbzoo1E5E
“identifier”: {
“type”: “dns”,
“challenges”: [
“type”: “dns-01”,
“wildcard”: true
2020-02-14 12:59:44,004:DEBUG:acme.client:Storing nonce: 0001IK4vVSJhXGnlA6_aNtx-bl7IByWPrA0lAFgbzoo1E5E
2020-02-14 12:59:44,005:DEBUG:acme.client:JWS payload:
2020-02-14 12:59:44,014:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/2818997907:
“protected”: “eyJub25jZSI6ICIwMDAxSUs0dlZTSmhYR25sQTZfYU50eC1ibDdJQnlXUHJBMGxBRmdiem9vMUU1RSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYXV0aHotdjMvMjgxODk5NzkwNyIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC83MjIyMjkwNiIsICJhbGciOiAiUlMyNTYifQ”,
“payload”: “”,
“signature”: “EtR5c-sLi7fOxy8qFUngCXFH30c_KDfar-fpvIxpRxtqqtNNbMjOUPtBHs9ae74Ptowl4bRjwp08IvZcoYw63NJtSUzM5PE3Oi4fJjiAVS8svzpTEWHZq7Y2FFZkZ64jKpRWGk6eR_ZAzGGDVkTP9NYPCQ3-07LyG0IdXtBpMPaMdZVbpQvn32NBZs56ZKTLTMKknDHJ17za5RbgKqKpwCo-x-QYHJokWjOk7dpW5wErV8AYNmbEKJKSb5H5leKYB5ELdJnf03IXwY6QdPliFpQleT1VO4t1WvlFp5v3T4gP12EOx26AzP_r_qQTRWL3pHrIAABcSrpPmjk02uPlLg”
2020-02-14 12:59:44,061:DEBUG:urllib3.connectionpool:“POST /acme/authz-v3/2818997907 HTTP/1.1” 200 795
2020-02-14 12:59:44,062:DEBUG:acme.client:Received response:
HTTP 200
content-length: 795
server: nginx
date: Fri, 14 Feb 2020 20:59:44 GMT
replay-nonce: 00015urcOSzm1pBl1OXtOyGf3nw70_9W8tMr1ORx4jbTuxM
“identifier”: {
“type”: “dns”,
“challenges”: [
“type”: “http-01”,
“url”: “https://acme-v02.api.letsencrypt.org/acme/chall-v3/2818997907/lEsnfA”,
“token”: “Z7g1Q6R4NjJxyOssw_z020YISQBbbTWC4LnQj8i8Eo4”
“type”: “dns-01”,
“url”: “https://acme-v02.api.letsencrypt.org/acme/chall-v3/2818997907/mA2FfQ”,
“type”: “tls-alpn-01”,
“url”: “https://acme-v02.api.letsencrypt.org/acme/chall-v3/2818997907/-A47jA”,
2020-02-14 12:59:44,063:DEBUG:acme.client:Storing nonce: 00015urcOSzm1pBl1OXtOyGf3nw70_9W8tMr1ORx4jbTuxM
2020-02-14 12:59:44,064:INFO:certbot._internal.auth_handler:Performing the following challenges:
2020-02-14 12:59:44,064:INFO:certbot._internal.auth_handler:dns-01 challenge for mountaintrips.com
2020-02-14 12:59:44,068:INFO:certbot._internal.hooks:Running manual-auth-hook command: /etc/letsencrypt/renewal-hooks/pre/authenticate.sh
2020-02-14 13:01:14,611:INFO:certbot._internal.hooks:Running manual-auth-hook command: /etc/letsencrypt/renewal-hooks/pre/authenticate.sh
2020-02-14 13:02:45,325:INFO:certbot._internal.auth_handler:Waiting for verification…
2020-02-14 13:02:45,326:DEBUG:acme.client:JWS payload:
“type”: “dns-01”,
“resource”: “challenge”
2020-02-14 13:02:45,333:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/2818997906/glTonA:
“protected”: “eyJub25jZSI6ICIwMDAxNXVyY09Tem0xcEJsMU9YdE95R2Yzbnc3MF85Vzh0TXIxT1J4NGpiVHV4TSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvY2hhbGwtdjMvMjgxODk5NzkwNi9nbFRvbkEiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNzIyMjI5MDYiLCAiYWxnIjogIlJTMjU2In0”,
“payload”: “ewogICJ0eXBlIjogImRucy0wMSIsIAogICJyZXNvdXJjZSI6ICJjaGFsbGVuZ2UiCn0”,
“signature”: “n07VTkWbVxDNQ14A0oIO5GZMDOzFZwSgU2hQ6W_33o3uHq3V0EIUa842MBuwvobpNwlXk4NdPs_vQogc4oGJr6rz3iQA8_lL9eLxJ07oyhylgoE49mdX7J4lbdEbF_g_JizYrcKUGxnBcP_X2tO5TFpRiuzlt1eOn3LKDo_wQ2Ea6HhZX9aJjifBFrPCSr4546xlksGgFSUtWJwdZvWR96-QRjtbSIJnRy243rL8XbJIU3uCq5Z4686psBqLFQih7GcrLSMDWvAfcE6Cob_JLqcIRgibjLFqdpjnQNTvdlG0ULjUFAk4Nrl5cFujpaJuxxxqKBwjy_6KdpaLxtQIhA”
2020-02-14 13:02:45,386:DEBUG:urllib3.connectionpool:“POST /acme/chall-v3/2818997906/glTonA HTTP/1.1” 200 184
2020-02-14 13:02:45,387:DEBUG:acme.client:Received response:
HTTP 200
content-length: 184
server: nginx
link: https://acme-v02.api.letsencrypt.org/directory;rel=“index”, https://acme-v02.api.letsencrypt.org/acme/authz-v3/2818997906;rel=“up”
location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/2818997906/glTonA
date: Fri, 14 Feb 2020 21:02:45 GMT
replay-nonce: 0002J1ITVU7Rrinr_3NBHt17WQAVGF0vEnkitxzvX1_WR2Q
“type”: “dns-01”,
2020-02-14 13:02:45,388:DEBUG:acme.client:Storing nonce: 0002J1ITVU7Rrinr_3NBHt17WQAVGF0vEnkitxzvX1_WR2Q
2020-02-14 13:02:45,389:DEBUG:acme.client:JWS payload:
“type”: “dns-01”,
2020-02-14 13:02:45,395:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/2818997907/mA2FfQ:
“protected”: “eyJub25jZSI6ICIwMDAySjFJVFZVN1JyaW5yXzNOQkh0MTdXUUFWR0YwdkVua2l0eHp2WDFfV1IyUSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvY2hhbGwtdjMvMjgxODk5NzkwNy9tQTJGZlEiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNzIyMjI5MDYiLCAiYWxnIjogIlJTMjU2In0”,
“signature”: “ggVd7T8gfVK2SrTcucEb7b6jFXQmLR19BlwaRZfX7rhZbnExFDumrtLBFKs_irZujCbJ2LOBB9TI7-RF_wyePriOrVnqNjwVVYR_eFxIjhz6AjAjtU2vNRAbHQyXWBOw3Wn6uIQ8eA4oDAW1P1FA1fAgLbAMhpW8Ck6rupVljRbPccvw34gdJD8K8nWP03nACZVaLzf9ls1PWdgGuQckgGvmJwxOTZzk5aWThv-Gl-k2exJ5ph2K1IhR7RhzMuY4RWh2UdNciIDPhkzWW5dGf3RYCda31u80hhra_MtsXWU9uRyHSc_2tp5PXDNICt-5wgeCtNff1BY3pxqh5D-CLw”
2020-02-14 13:02:45,445:DEBUG:urllib3.connectionpool:“POST /acme/chall-v3/2818997907/mA2FfQ HTTP/1.1” 200 184
2020-02-14 13:02:45,446:DEBUG:acme.client:Received response:
HTTP 200
content-length: 184
server: nginx
link: https://acme-v02.api.letsencrypt.org/directory;rel=“index”, https://acme-v02.api.letsencrypt.org/acme/authz-v3/2818997907;rel=“up”
location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/2818997907/mA2FfQ
replay-nonce: 0002hqCUciUymD1mjtO9hgqwpmi4xRN4vTNkpFcrsN9Co3g
“type”: “dns-01”,
2020-02-14 13:02:45,447:DEBUG:acme.client:Storing nonce: 0002hqCUciUymD1mjtO9hgqwpmi4xRN4vTNkpFcrsN9Co3g
2020-02-14 13:02:46,449:DEBUG:acme.client:JWS payload:
2020-02-14 13:02:46,454:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/2818997906:
“protected”: “eyJub25jZSI6ICIwMDAyaHFDVWNpVXltRDFtanRPOWhncXdwbWk0eFJONHZUTmtwRmNyc045Q28zZyIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYXV0aHotdjMvMjgxODk5NzkwNiIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC83MjIyMjkwNiIsICJhbGciOiAiUlMyNTYifQ”,
“payload”: “”,
“signature”: “WTQ-SiRLzFcNCPq5waI_SP9Krc4oYrgDI6jWTGkTdCsgkV0KQXuqj8daIakIvOpCK0QK0HR6AbRjomDqqn93dIGnPyLO_TY28xwO9MRfZlNJ6IbwQSd2y8LK_gcThJqtpZm59_4gqCnYZSB1CIy_FV-bEbMfpmr14J34TUOBV3ZQ2jBd6dq3guQ0ALQPHCwhf0cJrOy14RCcDh0ycYEZC_CJa8XOiyfNwm-v-LFXhji3H6vKlEq2yLGqfMAp5XqEo0kPUbMS6AVae9gvWQLhyPeEA4-kXJEHskI0o4LecCKZKu-PPh3yajM_xN4_TduaBcU5mOzqcZIToOrb7Z2tHA”
2020-02-14 13:02:46,498:DEBUG:urllib3.connectionpool:“POST /acme/authz-v3/2818997906 HTTP/1.1” 200 629
2020-02-14 13:02:46,499:DEBUG:acme.client:Received response:
HTTP 200
content-length: 629
server: nginx
date: Fri, 14 Feb 2020 21:02:46 GMT
replay-nonce: 0002pTLCpq-EJ9YOr4f-JC2mzN-YelAHgdNi-ZQ_ifxBtRw
“identifier”: {
“type”: “dns”,
“challenges”: [
“type”: “dns-01”,
“error”: {
“status”: 403
“wildcard”: true
2020-02-14 13:02:46,499:DEBUG:acme.client:Storing nonce: 0002pTLCpq-EJ9YOr4f-JC2mzN-YelAHgdNi-ZQ_ifxBtRw
2020-02-14 13:02:46,501:DEBUG:acme.client:JWS payload:
2020-02-14 13:02:46,506:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/2818997907:
“protected”: “eyJub25jZSI6ICIwMDAycFRMQ3BxLUVKOVlPcjRmLUpDMm16Ti1ZZWxBSGdkTmktWlFfaWZ4QnRSdyIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYXV0aHotdjMvMjgxODk5NzkwNyIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC83MjIyMjkwNiIsICJhbGciOiAiUlMyNTYifQ”,
“payload”: “”,
“signature”: “q51-eWyKsp3iMvGd_DW63YHKpYzAMQnm4-TCAYA0qugsPosPbMqBv5fdYZo5y9PgMgirOPmUSu1o_0Ocg_n9aQTYmp51nV7OYU-txX6x2rL5r_P4mai15OOkJgJb-P8zvyF1inr8Huld533l07zFH8O9A5NI9lyz4oWoYMjGrXmwE2wbQ-3vY2usvjN7ZPvQbl6U7ZPOmqV5tameMl4E4tYNVjVUuvUSnrfqTlf5wpR825L6V25KxBFUF0tG96dKiBNz7wOx3UCsF1Wzfp2wOdmd8N8o9VR-ThOeTCt57AFLU0GTnLsWruDgIu6fvVEAGogTEhqyOdiZcCEHB9X5ZA”
2020-02-14 13:02:46,550:DEBUG:urllib3.connectionpool:“POST /acme/authz-v3/2818997907 HTTP/1.1” 200 464
2020-02-14 13:02:46,551:DEBUG:acme.client:Received response:
HTTP 200
content-length: 464
server: nginx
replay-nonce: 0001CFma0RwhK-JcgEDwGqbG_upuX4lEquPX9OuLmdX9pDk
“identifier”: {
“type”: “dns”,
“status”: “valid”,
“expires”: “2020-03-15T21:02:45Z”,
“challenges”: [
“type”: “dns-01”,
“status”: “valid”,
“token”: “Z7g1Q6R4NjJxyOssw_z020YISQBbbTWC4LnQj8i8Eo4”,
“validationRecord”: [
“hostname”: “mountaintrips.com”
2020-02-14 13:02:46,551:DEBUG:acme.client:Storing nonce: 0001CFma0RwhK-JcgEDwGqbG_upuX4lEquPX9OuLmdX9pDk
2020-02-14 13:02:46,552:WARNING:certbot._internal.auth_handler:Challenge failed for domain mountaintrips.com
2020-02-14 13:02:46,552:INFO:certbot._internal.auth_handler:dns-01 challenge for mountaintrips.com
2020-02-14 13:02:46,553:DEBUG:certbot._internal.reporter:Reporting to user: The following errors were reported by the server:
Domain: mountaintrips.com
Detail: Incorrect TXT record “h_O_dPHpTQIkmGgooCMDPsQ2Z16W5auV09GCRohIB4Q” found at _acme-challenge.mountaintrips.com
I think what needs to be understood in this context is that DNS is capable of serving multiple TXT records under a single label.
For example, one of my test domains:
$ dig +noall +answer _acme-challenge.foo.monkas.xyz TXT
_acme-challenge.foo.monkas.xyz. 594 IN  TXT     "23DmSWvjBnO9sDgvJQ1rVsuGNMOUC2OdaRP8IlhykbY"
_acme-challenge.foo.monkas.xyz. 594 IN  TXT     "rum78MgEmL4lkkem8N3Dz9eaXjYLPikcA_bywhLKhzk"
GoDaddy allows you to create this record set by either specifying them all at once in the PUT call, or using the PATCH call to add one to the existing record set.
If it helps with understanding, it's exactly the same as having multiple A records for a given label when using DNS round robin.
Yes I know that. But when you have multiple records (A, TXT, etc…), when you query them, you will get a random response. So unless LE is requesting all TXT records and parsing through those, the authentication will potentially fail.
Yes. Let's Encrypt asks the authoritative DNS servers for all the TXT records under the label, and then checks if any one of them matches the one it's looking for.
Here is the literal text from RFC8555:
To validate a DNS challenge, the server performs the following steps:
  1. Compute the SHA-256 digest [FIPS180-4] of the stored key
    authorization
  2. Query for TXT records for the validation domain name
  3. Verify that the contents of one of the TXT records match the
    digest value
Yes - this is my problem…
Aha! Ok, let me try this. Thank you.
Perfect. I changed the PUT to PATCH but it throws an error:
“code”: “NOT_FOUND”,
“message”: “Not Found : The requested resource was not found”
Must be something else required in the payload. I am sending:
[{ “data”: “4i67-toZ_wK9JCOlcxibuSm4d8EZGUBSvljrVAysXMM”, “name”: “_acme-challenge”, “ttl”: 600 }]
Mmmm, so, your original script used this API endpoint:
PUT /v1/domains/{domain}/records/{type}/{name}
The PATCH endpoint has this prototype however:
PATCH /v1/domains/{domain}/records
So I believe you need to chop off the /{type}/{name}, and then change your request body to something like:
  "name": "${DNS_REC_NAME}",
  "type": "TXT",
  "data": "${DNS_REC_DATA}",
  "ttl": "${DNS_REC_TTL}"
(Edit: might need to be additionally wrapped as an array [] as in your first example? Dunno, unclear).
Highly recommend lowering TTL as low as you can, “1” if possible. It makes a difference if you are running Certbot multiple times within 1 minute - Let’s Encrypt clamps TTLs to 60 seconds.
I don’t have GoDaddy so I can’t test this for you, but check the docs.
In the GoDaddy API, the lowest “custom” TTL is 600. Does the API allow you to go lower? Thanks for that catch. I am trying that now. Appreciate the assist.
No idea. It’s no huge deal if you need to set 600. Just be wary that Let’s Encrypt does have a 1 minute DNS cache on its resolver … so wait 60 seconds between attempts.
Looks like no.
“code”: “INVALID_BODY”,
“fields”: [
“code”: “UNKNOWN_RESTRICTION”,
“message”: “must have a minimum value of 600”,
“path”: “records[0].ttl”
“message”: "Request body doesn’t fulfill schema, see details in fields"
I have those sleep timers in the scripts for this reason and I learned that one more or less by trial and error. Mine are set at 90 sec and that seems to be enough time for both ends.
