I have been using letsencrypt client for my domain using TLS-SNI-01 without any issues. With support being removed for TLS-SNI-01 and having a version that was not upgradeable I decided to switch to certbot client and use HTTP challenge instead.
My domain is: apps dot twexxt dot com
I ran this command: sudo /usr/bin/certbot --apache --preferred-challenges http
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/apps.twexxt.com.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
http-01 challenge for apps.twexxt.com
Enabled Apache rewrite module
Waiting for verification…
Failed authorization procedure. apps.twexxt.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://apps.twexxt.com/.well-known/acme-challenge/ZmikhkFUoDiZDZCmaC-QnuhJT-mBcFm57sGIh87XzLs: “Apache Tomcat/7.0.52 (Ubuntu) - Error report<!–H1 {font-family:Tahoma,Arial,sans-serif;color:”
My web server is (include version): Tomcat 7.0.52
The operating system my web server runs on is (include version): Ubuntu 14.04 (trusty)
My hosting provider, if applicable, is: aws
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.28.0
I am still getting the same error.
The output was:
Using the webroot path /var/lib/tomcat7/webapps for all unmatched
domains.
"Apache Tomcat/7.0.52 (Ubuntu)
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
# However, you must set it for any further virtual host explicitly. #ServerNamewww.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
JkMount /* worker1
Thank you, Juergen.
Using the actual root path for tomcat worked:
sudo certbot run -a webroot -i apache -w /var/lib/tomcat7/webapps/ROOT/ -d apps.twexxt.com
