More than 1 certificate
I run command
sudo certbot certificates
and there are more than 1 certificate
Found the following certs:
Certificate Name: website.com-0001
Domains: website.com
Expiry Date: 2017-10-17 11:17:00+00:00 (VALID: 80 days)
Certificate Path: /etc/letsencrypt/live/website.com-0001/fullchain.pem
Private Key Path: /etc/letsencrypt/live/website.com-0001/privkey.pem
Domains: website.com www.website.com
Expiry Date: 2017-08-17 23:21:00+00:00 (VALID: 19 days)
Certificate Path: /etc/letsencrypt/live/website.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/website.com/privkey.pem
Certificate Name: www.website.com
Domains: www.website.com
Certificate Path: /etc/letsencrypt/live/www.website.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.website.com/privkey.pem
How do I know which cert my website is using? Should I remove the unused certs?
That's what web configuration files tell you.
Alternatively you can use openssl to figure out the thumbprint of the certificate and check it that way.
Andrei
