I added three Let’sEncrypt certificates for three domains with their own distinct websites.
The certificates show as follows:
Found the following certs:
Certificate Name: mydomain1.info
Domains: mydomain1.info
Expiry Date: 2020-01-08 13:49:13+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/mydomain1.info/fullchain.pem
Private Key Path: /etc/letsencrypt/live/mydomain1.info/privkey.pem
Certificate Name: www.mydomain2.com
Domains: www.mydomain2.com mydomain2.com
Expiry Date: 2020-01-08 15:12:43+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.mydomain2.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.mydomain2.com/privkey.pem
Certificate Name: www.mydomain3.ca
Domains: www.mydomain3.ca mydomain3.ca
Certificate Path: /etc/letsencrypt/live/www.mydomain3.ca/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.mydomain3.ca/privkey.pem
Unfortunately, when I test mydomain2.com or mydomain3.ca on www.ssllabs.com I get the following errors for both
Certificate name mismatch
Try these other domain names (extracted from the certificates): mydomain1.info
The web site does not use SSL, but shares an IP address with some other site that does
Something seems to have a problem identifying the correct certificates and wonder why the respective certificates of mydomain2 and mydomain3 are not recognized.
It seems to indicate that LetsEncrypt cannot handle more than one certificate per IP address, although I find that unlikely. I am by no means a Linux administrator, but from what I have researched, I understand that the issue of dealing with multiple domains on a single IP address and even the same port has long been resolved and applies to the versions of the packages installed on my server
CentOS 6.10
httpd v2.2.15-60.el6.6vm
mod_ssl v2.2.15-60.el6.6vm
openssl v1.0.1e-58.el6_10
libcurl v7.19.7-53.el6_9
There are also errors when I restart httpd
[Thu Oct 10 13:54:50 2019] [warn] VirtualHost xx.xxx.xxx.xx:443 overlaps with VirtualHost xx.xxx.xxx.xx:443, the first has precedence, perhaps you need a NameVirtualHost directive
The httpd.conf file already contains the NameVirtualHost directive ahead of the < VirtualHost > statements
Any explanations, and especially suggestions on how to correct this issue, are most welcome.
