My domain is: nttec.com
I ran this command: certbot --apache -d www.nttec.com -d nttec.com
http-01 challenge for nttec.com
http-01 challenge for www.nttec.com
Created an SSL vhost at /etc/httpd/sites-available/nttec.com-le-ssl.conf
Deploying Certificate to VirtualHost /etc/httpd/sites-available/nttec.com-le-ssl.conf
Enabling site /etc/httpd/sites-available/nttec.com-le-ssl.conf by adding Include to root configuration
Deploying Certificate to VirtualHost /etc/httpd/sites-available/nttec.com-le-ssl.confPlease choose whether or not to redirect HTTP traffic to HTTPS, removing HTTP access.
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Redirecting vhost in /etc/httpd/sites-enabled/nttec.com.conf to ssl vhost in /etc/httpd/sites-available/nttec.com-le-ssl.conf
Congratulations! You have successfully enabled https://www.nttec.com and
https://nttec.comYou should test your configuration at:
SSL Server Test: www.nttec.com (Powered by Qualys SSL Labs)
SSL Server Test (Powered by Qualys SSL Labs)
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/www.nttec.com/fullchain.pem
/etc/letsencrypt/live/www.nttec.com/privkey.pem
Your cert will expire on 2019-03-13. To obtain a new or tweaked
with the "certonly" option. To non-interactively renew all of
your certificates, run "certbot renew"If you like Certbot, please consider supporting our work by:
Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
The operating system my web server runs on is (include version): Cento 7
I have multiple domain on one IP address, all the other domain in it successfully got their certificate for both www and non-www and all this domain is serving the same content from the same folder.
all this domain have their own seperate vhost file which contain this information
<VirtualHost *:80>
ServerName nttec.com
ServerAlias *.nttec.com
DocumentRoot /home/nttec/public_html
<Directory "/home/nttec/public_html">
Require all granted
</Directory>
ErrorLog logs/nttec.com-error_log
CustomLog logs/nttec.com-access_log common
my server hostname: nttec.com
except for this domain, I have tired to generate a certificate for it but end-up with Error - Certificate isn't trusted, RemoteCertificateNameMismatch, RemoteCertificateChainErrors
NET::ERR_CERT_AUTHORITY_INVALID
