Mobil devices SSL fail
Hello!
I have installed Let’s Encrypt on my server (Ubuntu 16.04), i configure my certs on apache2,
I use this to configure
SSLEngine on
SSLProxyEngine on
SSLCertificateFile /etc/letsencrypt/live/softlinex.net/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/softlinex.net/privkey.pem
    <FilesMatch "\.(php|py)$">
            SSLOptions +StdEnvVars
    </FilesMatch>
    BrowserMatch "MSIE [2-6]" \
            nokeepalive ssl-unclean-shutdown \
            downgrade-1.0 force-response-1.0
    BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown
When i access to my page from computer all works very well, but when i try do it from a mobil device (smart phone, tablet) i have and error saying “this connection is not verified”
What i need chage to solve id.
Thanks for your help and sorry for my English
You need to include the chain.pem or fullchain.pem
If you have apache < 2.8 then use
SSLCertificateChainFile /etc/letsencrypt/live/softlinex.net/chain.pem
if you have apache > 2.8 then use
SSLCertificateFile /etc/letsencrypt/live/softlinex.net/fullchain.pem
You will need to reload apache once you have made the changes.
You need the intermediate certificate, which confirms to clients that Let’s Encrypt is a real certificate authority. You can check this with https://www.ssllabs.com/ssltest/; be sure that your configuration refers to fullchain.pem (for newer versions of Apache) or chain.pem (for older versions).
That works fine for me!
Thanks!
