@bmw, do you have any thoughts about this? I don’t immediately see anything wrong.
I can see that the plugin created binding for the certs however i suspect there is another config for IPV6 which is overwriting it.
Not sure what the precedence is in these cases.
the wrong cert was returned but i suspect this is due to the way apache configs are set up
Andrei
Thanks @schoen @ahaw021 for looking into it.
@ahaw021 ::: You are the man
Apache config was the issue here. Virtual host was set as with *:80 and IPv4 & IPv6 for 443.
What I did to fix: Applied IP addresses to both the ports for both (IPv4 & IPv6)
I am using webmin/virtualmin, so possibly missed it while adding websites to apache
All good now.
Thanks Again.
