Excuses if this is not certbot or LE centered but I'm hoping that someone might lead me into the right direction to where I can get further help:
Somehow I changed my system to ACME and zero SSL certificates. Anyway, from some point in time my certificate renewal didn't work any longer and I have no idea where to start to search.
I have a `/var/spool/cron/crontabs/acme` file, containing:
`50 21 * * * /usr/local/share/acme.sh/acme.sh --cron --home "/var/lib/acme/.acme.sh" > /dev/null`
My certificates should serve an email server (dovecot, postfix) and a web server.
/etc/dovecot/conf.d/10-ssl.conf:
ssl_cert = </var/lib/acme/.acme.sh/www.mydomain.org/fullchain.cer
ssl_key = </var/lib/acme/.acme.sh/www.mydomain.org/www.mydomain.org.key
ssl_ca =
The deploy-hook is supposed to generate
a file `/etc/haproxy/certs/www.mydomain.org.pem` which is the cert-file plus the key file glued together (haproxy needs it that way).
I cannot find any longer the deploy hook. I can remember to have written the piece of shell code that does the glueing. Then I did a system upgrade from Ubuntu 22.04 to 24.04 and I believe from then on the mechanism got broken.
Any help would be welcome. Thank you.
