Acme.sh Not Invoking renewal hook
My domain is:myrevtel.com
I ran this command:37 0 * * * "/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null
My web server is (include version):apache2 (httpd)
The operating system my web server runs on is (include version): Linux Centos 7
My hosting provider, if applicable, is: AWS EC2
I can login to a root shell on my machine (yes or no, or I don't know):Yes
No!
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Acme.sh v2
I can successfully receive a renewal certificate. However, I am unable to execute:
Le_RenewHook='__ACME_BASE64__START_L3Jvb3QvLmFjaG1lLnNoL215cmV2dGVsLmNvbS9jb3B5Y2VydHMuc2g=_ACME_BASE64__END' in my /myrevtel.com.conf
The above BASE64 translates to : /root/.acme.sh/myrevtel.com/copycerts.sh
The script from the LE_RenewHook is never executed when a renewal certificate is issued.
Thanks!
Hi @Anointed
check
Same question.
Hello @Anointed,
I'm afraid it doesn't ;), it translates to:
/root/.achme.sh/myrevtel.com/copycerts.sh
Seems you mistyped the dir: .achme.sh instead of .acme.sh
You can edit your conf file and change this:
to this:
Le_RenewHook='__ACME_BASE64__START_L3Jvb3QvLmFjbWUuc2gvbXlyZXZ0ZWwuY29tL2NvcHljZXJ0cy5zaA==__ACME_BASE64__END_'
Cheers,
sahsanu
Eyes of a super-hero hawk! :heart:
[can see directly through Base64 encoding!]
