Acme.sh does not execute post hooks
My domain is: trustserv.de
I ran this command: none, the cronjob ran the acme.sh
see post hook ignored · Issue #3391 · acmesh-official/acme.sh · GitHub
Apache2
The operating system my web server runs on is (include version): Debian 10
no
acme.sh, latest
as mentioned in that bug report, i would assume that post hooks are executed, but they are not.
after i got that certificate, i have to manually restart apache2, dovecot, postfix, ... because the post hook is somehow ignored.
i dont understand the dev - i dont know what he means with "global", its one cert with about 10 subdomains.
unfortunately, he closed the ticket before asking anything so i guess he will never see my response. so i ask here, maybe someone can help me, thanks!
Welcome Back to the Let's Encrypt Community :slightly_smiling_face:
did not know that neilpang is also here registered :wink:
thanks for that fast message, maybe anyone else also uses post hooks and have an idea about that
dont want to waste the dev's time because of a config problem
I'm not too familiar with acme.sh, so I figured I'd get the call started. If someone else can answer before then, fantastic! :upside_down_face:
The cronjob you created (not the default one created by acme.sh), with incorrect syntax, didn't work properly. No surprise. The --post-hook is to be used when you initially issue the cert (as explained at the link he intended to give: Create new page · acmesh-official/acme.sh Wiki · GitHub). It should not be used with --cron. Using --cron will renew any cert that's due for renewal.
Thanks for helping with this, @danb35. I'd give you a like, but I'm out right now. :sparkling_heart:
thanks, but i created the certs initially without any hook. can i somehow add this now to the acme.sh?
i usually start (more or less complex things) step by step. that means: first issue a simple certificate, then issue a certificate with one subdomain, see if it works... continue until everything works with that, then add the next subdomain. last step, make everything automatic.
You can edit the conf file for your domain and replace the variable Le_PostHook='' with one with your command/commands but this line must be in a special format.
Based on the issue you raised on Github, your certhome is /etc/acme/ and your fake domain is mydomain.de so your conf file is /etc/acme/mydomain.de/mydomain.de.conf and the command you want to launch in post hook is systemctl restart apache2 postfix dovecot (I would use reload instead of restart but...)
First execute this command:
echo "Le_PostHook='__ACME_BASE64__START_$(echo -n 'systemctl restart apache2 postfix dovecot' | openssl base64 -e)__ACME_BASE64__END_'"
And you will get this output:
Le_PostHook='__ACME_BASE64__START_c3lzdGVtY3RsIHJlc3RhcnQgYXBhY2hlMiBwb3N0Zml4IGRvdmVjb3Q=__ACME_BASE64__END_'
Edit the conf file /etc/acme/mydomain.de/mydomain.de.conf and replace Le_PostHook='' with the above line, save the conf file and you are done.
Cheers,
sahsanu
By the way, I would use reloadcmd instead of posthook so in your case, if you are not installing your certs to any other dir, this command will have the same effect, restart your services once you get a certificate for your domain.
/root/.acme.sh/acme.sh --install-cert -d mydomain.de --reloadcmd "systemctl restart apache2 postfix dovecot" --cert-home /etc/acme
Note: Keep in mind I recommend the use of reload instead of restart.
i will try this, thanks!
can you tell me why reloadcmd is better than posthook? does it have some negative impact when using posthook instead reloadcmd?
i modified the crontab now to:
23 2 * * * /root/.acme.sh/acme.sh --cron --home "/root/.acme.sh" --cert-home /etc/acme --reloadcmd "systemctl restart apache2 postfix dovecot"
if it again makes problems i report back here - again, thanks! :slight_smile:
edit: Add reloadcmd support for cron flag. by hexfusion · Pull Request #1814 · acmesh-official/acme.sh · GitHub
seems like this does also not work with --cron
so guess the easiest way is to just add the posthook in the .conf, right?
Because posthook runs after attempting to issue a certificate and reloadcmd runs after successfully installing certificates.
Correct, it won't work if you put in your crontab job.
Yes, or even easier, use the command I wrote in previous post to use reloadcmd.
Cheers,
sahsanu
but i have about 10 subdomains, that would mean i have to do something like:
/root/.acme.sh/acme.sh --install-cert -d mydomain.de -d www.mydomain.de -d mta-sts.mydomain.de -d [all other subdomains...] --reloadcmd "systemctl restart apache2 postfix dovecot" --cert-home /etc/acme
correct?
No, the --install-cert command must contain only one -d parameter with the name of your cert. The name of your cert is the name of the dir that contains your cert; /etc/acme/mydomain.de, /etc/acme/otherdomain.com, etc.
thanks, i executed that command and it took about 10 seconds. it was printing it executes the reloadcmd whats a bit strange, because i did not get a new certificate - i got a new one yesterday.
I forgot to mention that it executes the reloadcmd when you configure it (what you did right now). From now on it will only be executed when renewing the certs. Remember to left the entry in crontab as it was originally, without --post-hook nor --reloadcmd parameters.
the cron job in /var/spool/cron/crontabs/root contains
but whenever i run this command: /root/.acme.sh/acme.sh --install-cert -d mydomain.de --reloadcmd "systemctl restart apache2 postfix dovecot" --cert-home /etc/acme --debug
i get the following output:
[Fr 5. Feb 19:35:44 CET 2021] Lets find script dir.
[Fr 5. Feb 19:35:44 CET 2021] _SCRIPT_='/root/.acme.sh/acme.sh'
[Fr 5. Feb 19:35:44 CET 2021] _script='/root/.acme.sh/acme.sh'
[Fr 5. Feb 19:35:44 CET 2021] _script_home='/root/.acme.sh'
[Fr 5. Feb 19:35:44 CET 2021] Using default home:/root/.acme.sh
[Fr 5. Feb 19:35:44 CET 2021] Using config home:/root/.acme.sh
https://github.com/acmesh-official/acme.sh
v2.8.9
[Fr 5. Feb 19:35:44 CET 2021] Running cmd: installcert
[Fr 5. Feb 19:35:44 CET 2021] default_acme_server
[Fr 5. Feb 19:35:44 CET 2021] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org/directory'
[Fr 5. Feb 19:35:44 CET 2021] DOMAIN_PATH='/etc/acme/mydomain.de'
[Fr 5. Feb 19:35:44 CET 2021] Run reload cmd: systemctl restart apache2 postfix dovecot
[Fr 5. Feb 19:35:54 CET 2021] Reload success
it seems to me that this command is always executed, even when there is no new certificate
or do i have to run this only once and now the --cron knows how to handle that?
this is a wild magic thing then... which makes it pretty complicated
That command must be used only once per certificate, as you did it with your cert you don't need to execute it again and again.
It is not magic, that command adds the right variable with the right content in your certificate conf and cron command will read that conf file so as I said, you donn't need to execute the command more than once.
ok thanks, so --install-cert does not mean "i install/deploy that certificate" but means: i install some configuration stuff that has to do with that account/domain and the next time acme.sh runs those values are used.
thanks for clarification! maybe its because of missing english skills, was just a bit confusing to me
It means both, install/deploy the certificate and execute the comand the first time I execute it AND save those options in the certificate conf so cron will use those parameters when renewing the cert.
