Max retries exceeded with url: /directory
using a docker certbot image: certbot/certbot
My domain is: foxpropanda.com
[’–webroot’, ‘-w’, ‘/var/www/certbot’, ‘–email’, ‘ayelluas@gmail.com’, ‘-d’, ‘foxpropanda.com’, ‘-d’, ‘www.foxpropanda.com’, ‘–rsa-key-size’, ‘4096’, ‘–agree-tos’, ‘–force-renewal’]
2019-03-23 03:17:28,363:DEBUG:certbot.main:certbot version: 0.31.0
2019-03-23 03:17:28,363:DEBUG:certbot.main:Arguments: [’–webroot’, ‘-w’, ‘/var/www/certbot’, ‘–email’, ‘ayelluas@gmail.com’, ‘-d’, ‘foxpropanda.com’, ‘-d’, ‘www.foxpropanda.com’, ‘–rsa-key-size’, ‘4096’, ‘–agree-tos’, ‘–force-renewal’]
2019-03-23 03:17:28,363:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2019-03-23 03:17:28,381:DEBUG:certbot.log:Root logging level set at 20
2019-03-23 03:17:28,381:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2019-03-23 03:17:28,383:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2019-03-23 03:17:28,390:DEBUG:certbot.plugins.selection:Single candidate plugin: * webroot
Description: Place files in webroot directory
Entry point: webroot = certbot.plugins.webroot:Authenticator
Initialized: <certbot.plugins.webroot.Authenticator object at 0x7f7f68863f10>
Prep: True
2019-03-23 03:17:28,391:DEBUG:certbot.plugins.selection:Selected authenticator <certbot.plugins.webroot.Authenticator object at 0x7f7f68863f10> and installer None
2019-03-23 03:17:28,391:INFO:certbot.plugins.selection:Plugins selected: Authenticator webroot, Installer None
2019-03-23 03:17:29,936:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2019-03-23 03:17:29,938:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2019-03-23 03:17:34,944:DEBUG:certbot.log:Exiting abnormally:
File “/usr/local/bin/certbot”, line 11, in
load_entry_point(‘certbot’, ‘console_scripts’, ‘certbot’)()
File “/opt/certbot/src/certbot/main.py”, line 1365, in main
File “/opt/certbot/src/certbot/main.py”, line 1234, in certonly
le_client = _init_le_client(config, auth, installer)
File “/opt/certbot/src/certbot/main.py”, line 605, in _init_le_client
acc, acme = _determine_account(config)
File “/opt/certbot/src/certbot/main.py”, line 521, in _determine_account
config, account_storage, tos_cb=_tos_cb)
File “/opt/certbot/src/certbot/client.py”, line 181, in register
acme = acme_from_config_key(config, key)
File “/opt/certbot/src/certbot/client.py”, line 51, in acme_from_config_key
return acme_client.BackwardsCompatibleClientV2(net, key, config.server)
File “/opt/certbot/src/acme/acme/client.py”, line 814, in init
directory = messages.Directory.from_json(net.get(server).json())
File “/opt/certbot/src/acme/acme/client.py”, line 1152, in get
self._send_request(‘GET’, url, **kwargs), content_type=content_type)
File “/opt/certbot/src/acme/acme/client.py”, line 1101, in _send_request
response = self.session.request(method, url, *args, **kwargs)
File “/usr/local/lib/python2.7/site-packages/requests/sessions.py”, line 524, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python2.7/site-packages/requests/sessions.py”, line 637, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python2.7/site-packages/requests/adapters.py”, line 516, in send
raise ConnectionError(e, request=request)
ConnectionError: HTTPSConnectionPool(host=‘acme-v02.api.letsencrypt.org’, port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError(’<urllib3.connection.VerifiedHTTPSConnection object at 0x7f7f68851c50>: Failed to establish a new connection: [Errno -3] Try again’,))
2019-03-23 03:17:34,945:ERROR:certbot.log:An unexpected error occurred:
My web server is (include version): nginx 1.15.9
The operating system my web server runs on is (include version): nginx runs in a docker container under Alpine linux 3.9, host os is Ubuntu 18.10
My hosting provider, if applicable, is: Digital Ocean
Hi @hiphamster
is your server able to connect urls?
What happens if you run
curl www.google.com
or something else?
Your domain is invisible ( https://check-your-website.server-daten.de/?q=foxpropanda.com ):
http://foxpropanda.com/
138.68.229.55 -2 1.520 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 138.68.229.55:80
http://www.foxpropanda.com/
https://foxpropanda.com/
138.68.229.55 -2 1.513 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 138.68.229.55:443
https://www.foxpropanda.com/
http://foxpropanda.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
138.68.229.55 -2 1.524 V
Visible Content:
http://www.foxpropanda.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
Visible Content:
So it's impossible that Letsencrypt checks your file.
