Manually generated certificate works, but automatically generated one does not
The information below is what I get when I run the renwal command from the command line. Everything works fine and browsers are happy with the certs. I've been doing that manual process for years, but I'm trying to do things properly and automate the proccess. For three
months in a row, the automatically generated cert is bad. (It apparently uses a STAGING cert rather than the normal one.)
My fix each time has been to re-run the command manually (with the --force option, since it's shortly after the bad cert was generated) and then everything is fine until the automated task runs again and generates a bad cert.
I don't know what to do to debug this since (I thought) the automated script is runnings the same wacs command that the manual command uses).
I want to includes screen shots showing what an on-line ssl checker things of the bad (auto generated) and good (manually generated) certificates, but the system will only allow one embedded image. Here is the bad one
My domain is: fccnaper.dynalias.org
I ran this command: wacs --renew (or in this case: wacs --renew --force)
 Found 7 files older than 120 days in C:\ProgramData\win-acme\acme-v02.api.letsencrypt.org\Certificates, enable Cache.DeleteStaleFiles
 in settings.json to automatically delete these on each run.
 A simple Windows ACMEv2 client (WACS)
 Software version 2.2.9.1701 (release, pluggable, standalone, 64-bit)
 Connecting to https://acme-v02.api.letsencrypt.org/...
 Connection OK!
 Scheduled task looks healthy
 Please report issues at https://github.com/win-acme/win-acme
 Plugin IIS generated source fccnaper.dynalias.org with 1 identifiers
 Plugin Single created 1 order
 Force renewing [IIS] (any site), (any host)
 Using cache for [IIS] (any site), (any host). To get a new certificate within 1 days, run with --nocache.
 Store with CertificateStore...
 Installing certificate in the certificate store
 Replacing certificate [IIS] (any site), (any host) @ 2025/4/4 12:49:53 in store WebHosting
 Installing with IIS...
 No bindings have been changed while updating site 1
 Next renewal due after 2025/4/29 18:03:43
 Renewal for [IIS] (any site), (any host) succeeded
 Sending e-mail with subject Certificate renewal [IIS] (any site), (any host) completed to peter@fales-lorenz.net
 Force renewing [IIS] Default Web Site, (any host)
 Using cache for [IIS] Default Web Site, (any host). To get a new certificate within 1 days, run with --nocache.
 Replacing certificate [IIS] Default Web Site, (any host) @ 2025/4/4 12:50:03 in store WebHosting
 Next renewal due after 2025/4/29 18:03:45
 Renewal for [IIS] Default Web Site, (any host) succeeded
 Sending e-mail with subject Certificate renewal [IIS] Default Web Site, (any host) completed to peter@fales-lorenz.net
My web server is (include version): IIS
The operating system my web server runs on is (include version): Windows 10
My hosting provider, if applicable, is: NA
 Connection OK!
Here is the "good" certificate I get when I run the wacs command manually:
Yeah, your "bad" cert is definitely from the Let's Encrypt Staging system and not production. Those are great for testing the cert request mechanism but not for actual use (as you note).
I am not very good at win-acme but I believe there is a settings.json file that keeps some options. Would you show the contents of that? Redact any personal data that might be there.
This json file is described here: win-acme
I figured it out. My face is red, but maybe the answer will help someone else...
I did not realize that I have TWO scheduled tasks. Apparently the task created with "wacs --test" creates a staging certificate every month. That overwrites the regular certificate which is only created (roughly) every three months.
The solution is to use the windows "Task Scheduler" to delete the win-acme task using the staging server.
