My domain is: noojee.org
certbot ‘–manual’, ‘–preferred-challenges=dns’, ‘-m’, ‘me@my.com.au’, ‘-d’, ‘slayer.noojee.org’, ‘–agree-tos’, ‘–manual-public-ip-logging-ok’, ‘–non-interactive’, ‘–manual-auth-hook=/home/bin/certbot_hooks/dns_auth’, ‘–manual-cleanup-hook=/home/bin/certbot_hooks/dns_cleanup’, ‘–work-dir=/etc/letsencrypt/work’, ‘–config-dir=/etc/letsencrypt/config’, ‘–logs-dir=/etc/letsencrypt/logs’, ‘–staging’
The command works correctly and a certificate is obtained.
The problem is that I’m trying to test my dns auth hook and it appears that once I successfully acquired a certificate that certbot no longer calls the dns auth hooks.
Complete logs at end.
During testing I need to have certbot call the auth hook every time.
nginx/1.18.0 (Ubuntu)
Ubuntu 20.04
namecheap
no.
or certbot-auto --version
if you’re using Certbot):
certbot 0.40.0
Entry point: manual = certbot.plugins.manual:Authenticator
Initialized: <certbot.plugins.manual.Authenticator object at 0x7f9108144160>
Prep: True
2020-07-28 14:17:22,187:DEBUG:certbot.plugins.selection:Selected authenticator <certbot.plugins.manual.Authenticator object at 0x7f9108144160> and installer None
2020-07-28 14:17:22,187:INFO:certbot.plugins.selection:Plugins selected: Authenticator manual, Installer None
2020-07-28 14:17:22,189:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-staging-v02.api.letsencrypt.org/acme/acct/14834518', new_authzr_uri=None, terms_of_service=None), a474c3171bb8388595a6d1cfa040e26c, Meta(creation_dt=datetime.datetime(2020, 7, 24, 5, 24, 31, tzinfo=<UTC>), creation_host='slayer4'))>
2020-07-28 14:17:22,189:DEBUG:acme.client:Sending GET request to https://acme-staging-v02.api.letsencrypt.org/directory.
2020-07-28 14:17:22,190:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org:443
2020-07-28 14:17:23,040:DEBUG:urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 724
2020-07-28 14:17:23,041:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Tue, 28 Jul 2020 04:17:22 GMT
Content-Length: 724
X-Frame-Options: DENY
"keyChange": "https://acme-staging-v02.api.letsencrypt.org/acme/key-change",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
"website": "https://letsencrypt.org/docs/staging-environment/"
"newAccount": "https://acme-staging-v02.api.letsencrypt.org/acme/new-acct",
"newNonce": "https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce",
"newOrder": "https://acme-staging-v02.api.letsencrypt.org/acme/new-order",
"revokeCert": "https://acme-staging-v02.api.letsencrypt.org/acme/revoke-cert",
"tSjy7Tofxig": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417"
2020-07-28 14:17:23,041:INFO:certbot.main:Obtaining a new certificate
2020-07-28 14:17:23,065:DEBUG:certbot.crypto_util:Generating key (2048 bits): /etc/letsencrypt/config/keys/0019_key-certbot.pem
2020-07-28 14:17:23,067:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/config/csr/0019_csr-certbot.pem
2020-07-28 14:17:23,067:DEBUG:acme.client:Requesting fresh nonce
2020-07-28 14:17:23,067:DEBUG:acme.client:Sending HEAD request to https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce.
2020-07-28 14:17:23,276:DEBUG:urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2020-07-28 14:17:23,277:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Tue, 28 Jul 2020 04:17:23 GMT
Link: <https://acme-staging-v02.api.letsencrypt.org/directory>;rel="index"
Replay-Nonce: 0001XxXKQTuD3hQCgwsPFpH-xJxBI_OI0ziFm0P5omX1flE
2020-07-28 14:17:23,277:DEBUG:acme.client:Storing nonce: 0001XxXKQTuD3hQCgwsPFpH-xJxBI_OI0ziFm0P5omX1flE
2020-07-28 14:17:23,277:DEBUG:acme.client:JWS payload:
b'{\n "identifiers": [\n {\n "type": "dns",\n "value": "slayer.noojee.org"\n }\n ]\n}'
2020-07-28 14:17:23,278:DEBUG:acme.client:Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/new-order:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNDgzNDUxOCIsICJub25jZSI6ICIwMDAxWHhYS1FUdUQzaFFDZ3dzUEZwSC14SnhCSV9PSTB6aUZtMFA1b21YMWZsRSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9uZXctb3JkZXIifQ",
"signature": "PUXgWSPY8ZzQ4m1x7isdqKMxngJdA6y-PwW9tMeVt27RwxkWI4E3upxxIZ6FldnRT_z13fnFfIaSpp5-DPY3xj9yvCvwwRqTSn3_m3nI54s46RHXNNx2RZnzwxKQP-4GcD44zBrPeJlC-ngTveRT7qrcJlK-3eTgnyxlYE72bmJt1cvqyOgEfPdOPMXqsTDV8JNI8s3B3juyrqBizN3MN7CGmEnbZBdNX_-a4x1Nd9-xhh6lv1Z__kiQEOh-B_--cC6pilZa7QwsdDwBGsyg6J-Un_xr86e-oPhf2AfYkASpkudj6EGuhNfeixGxDmi-ZIcSoIeWqdlJLG4qzZJgGg",
"payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogInNsYXllci5ub29qZWUub3JnIgogICAgfQogIF0KfQ"
2020-07-28 14:17:23,504:DEBUG:urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 358
2020-07-28 14:17:23,504:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 358
Boulder-Requester: 14834518
Location: https://acme-staging-v02.api.letsencrypt.org/acme/order/14834518/121986950
Replay-Nonce: 0002eDIWs_AdfgCOp-MnvHoA0U5TbGDIF64QQQQp9yq7oYA
"status": "ready",
"expires": "2020-08-04T04:17:23.391552568Z",
"identifiers": [
"type": "dns",
"authorizations": [
"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/83453523"
"finalize": "https://acme-staging-v02.api.letsencrypt.org/acme/finalize/14834518/121986950"
2020-07-28 14:17:23,504:DEBUG:acme.client:Storing nonce: 0002eDIWs_AdfgCOp-MnvHoA0U5TbGDIF64QQQQp9yq7oYA
2020-07-28 14:17:23,505:DEBUG:acme.client:JWS payload:
b''
2020-07-28 14:17:23,506:DEBUG:acme.client:Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/83453523:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNDgzNDUxOCIsICJub25jZSI6ICIwMDAyZURJV3NfQWRmZ0NPcC1NbnZIb0EwVTVUYkdESUY2NFFRUVFwOXlxN29ZQSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My84MzQ1MzUyMyJ9",
"signature": "TdIRHw98GOhFyGl-8_sh5sXia94iTFgC2d-IRYkRIHLaxBCfCA--W3OxzhXnDaaWOhlItNwXw2LP68kS7G9qijiLhaagmENfcjbVs75Kplcz-a844VESCbPC6MqxKC3l12lsfUBY6BCcfWDV3aexurLB76a8qsqW1lAeoTKEA_EognANa5bQ1u0pbiW80ADGN-ei-_YgLHkBN5T7cTfHdnfD-PRISM5vOAh34WOOs5inTk25mYFI-qWrKGOORWCVdzbkw4i2zAUSE4fYnHPQoNEG1uXeK5ygDY8AbddFMsLdYVAK8NrKdeY_SgaQHk3TXnBm4rIxm7mx7eUfpSxlmw",
"payload": ""
2020-07-28 14:17:23,718:DEBUG:urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/83453523 HTTP/1.1" 200 727
2020-07-28 14:17:23,718:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 727
Replay-Nonce: 0002ODmOe0sUm17PL9vnZz16putcIEZxGusUYDfn6PMstR4
"identifier": {
"type": "dns",
"status": "valid",
"expires": "2020-08-26T05:51:07Z",
"challenges": [
"type": "http-01",
"status": "valid",
"url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/83453523/ZksApw",
"token": "RDgx7jzLq2Mg9F59vD0gLeTac-4t6qo4NJvDcQ3P7Mg",
"validationRecord": [
"url": "http://slayer.noojee.org/.well-known/acme-challenge/RDgx7jzLq2Mg9F59vD0gLeTac-4t6qo4NJvDcQ3P7Mg",
"hostname": "slayer.noojee.org",
"port": "80",
"addressesResolved": [
"14.201.92.199"
"addressUsed": "14.201.92.199"
2020-07-28 14:17:23,718:DEBUG:acme.client:Storing nonce: 0002ODmOe0sUm17PL9vnZz16putcIEZxGusUYDfn6PMstR4
2020-07-28 14:17:23,719:DEBUG:certbot.client:CSR: CSR(file='/etc/letsencrypt/config/csr/0019_csr-certbot.pem', data=b'-----BEGIN CERTIFICATE REQUEST-----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\nlVkahFJtBeY=\n-----END CERTIFICATE REQUEST-----\n', form='pem')
2020-07-28 14:17:23,719:DEBUG:acme.client:JWS payload:
b'{\n "resource": "new-cert",\n "csr": "MIICdDCCAVwCAQIwADCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAKi1Oqt8ZRetGwVWoihd_mj1SZo_e1Ztpg_PC_WixhH57i769fy4USIRqHH2P33te2gbyw8zm87zgSVaYv_fPB5iZ84rF2oLrlGEvn9DnHMS-qQXvtAb_c7VEcax5d4kjYSWX5i3OCpnDB2ghwzUO4ZXDL9BCekQZUSKEHiZOrw_h-6FfnBVLCwfPMfePX7RFEkNSWTXYkTLx3TLYQKsu8fyOXenFgUSF5ZgwWB4LhsD0VAYPcZ2N7uR2yBiXiDYohXIkkiqgW3KjkJ8mH9qrOxLmSssxavTlLwaSstMnOwPymmSZ80f6hIYnTnCSeIxJIMu28nR_zuOP8WK4HH9_m0CAwEAAaAvMC0GCSqGSIb3DQEJDjEgMB4wHAYDVR0RBBUwE4IRc2xheWVyLm5vb2plZS5vcmcwDQYJKoZIhvcNAQELBQADggEBAIEphuPjFSqGn5r12BVeLODopBYdhwMsFKd7pTdwWVlw49XgU-qJAzSKmdpHq6Vc_tIlg8VvYlURDbwaih_U8R3gaN6FsRTw3kw3Q3XLsUTqFvJZodCz9IZE7smZ1FMPoRuoVWY22aCDLccL3jCazI1RWw-e30IZ4Eoj_0lIgm0_W7c3aSSsSsnttXAMXX88P_fXB0aAH6p3MNhFS_4AoszQcsQ2FggRHDqxxnFjG0PSI0K0641CUg4iG9WyNmJHef2wRfCJ8VVLx6Q0kdpteMA7gXlQWS_s4ZT5IeQ9i1Y8N-pueMuAQTsuGlbijpHsZ5-ZDflm-7F8lVkahFJtBeY"\n}'
2020-07-28 14:17:23,720:DEBUG:acme.client:Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/finalize/14834518/121986950:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNDgzNDUxOCIsICJub25jZSI6ICIwMDAyT0RtT2Uwc1VtMTdQTDl2blp6MTZwdXRjSUVaeEd1c1VZRGZuNlBNc3RSNCIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9maW5hbGl6ZS8xNDgzNDUxOC8xMjE5ODY5NTAifQ",
"signature": "RVi36R5oawWY5r0PTX99wtm4u-FQCZX_oGokcENI86FSTSFhY-QP4-KeNrKNiN6aoh1MZK4mYUr2_-M5oN5RUiw5OrMKv_381t7Ht9xH2bbVsKeR5puxZTafNfmqF54MESEMWGjwRVvomet8kPl3LIfjYrN6sWQypb06SxMER5t5lqG3YN3YgUUsPqISoSQoErjgt5GOD2m34VEphvXaJU6Q0bAXkSGMv0Qb_KVH3CVAceb_HBZt265ylYmTTZOxS4bU4Gx5rSuR-_iIbUkvP_XhB19vw2QogQZ16Co6U6k7JxVSeqTF88Q6g_myQCUCzwWrdwpSe2o8DUxCupp0eg",
"payload": "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"
2020-07-28 14:17:24,409:DEBUG:urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/finalize/14834518/121986950 HTTP/1.1" 200 460
2020-07-28 14:17:24,409:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Tue, 28 Jul 2020 04:17:24 GMT
Content-Length: 460
Replay-Nonce: 0002nK9-HlBdzcjx2nGowM8vvYk-YjCsF0Q9dfjSVlh6prA
"status": "valid",
"expires": "2020-08-04T04:17:23Z",
"identifiers": [
"type": "dns",
"authorizations": [
"finalize": "https://acme-staging-v02.api.letsencrypt.org/acme/finalize/14834518/121986950",
"certificate": "https://acme-staging-v02.api.letsencrypt.org/acme/cert/fa6452755670e6763970b37a7d35646ff5e3"
2020-07-28 14:17:24,409:DEBUG:acme.client:Storing nonce: 0002nK9-HlBdzcjx2nGowM8vvYk-YjCsF0Q9dfjSVlh6prA
2020-07-28 14:17:25,410:DEBUG:acme.client:JWS payload:
b''
2020-07-28 14:17:25,411:DEBUG:acme.client:Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/order/14834518/121986950:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNDgzNDUxOCIsICJub25jZSI6ICIwMDAybks5LUhsQmR6Y2p4Mm5Hb3dNOHZ2WWstWWpDc0YwUTlkZmpTVmxoNnByQSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9vcmRlci8xNDgzNDUxOC8xMjE5ODY5NTAifQ",
"signature": "qxQ5eEF877SOnjy5l8Di7-hWvz0HZEenSPF1e_lragLsHoFPWTruPTMomu6hmlaZHmXBlQpsmDf88rBIrz_O7O43z_FhHgf_yXBf_W6ZK7mgSBQTNuW85Fk9V7NpAd-Ps4ytkifg9hcgE82w04Awxp0-Yx4xV5RUTlKMjK69xjsMR-ahzds37fh41G2VrSEdKgwKwh22aKii9PcvnV1798jqKq0GQMdTa4S7GWdLbe_LiQ_3dw5WLeFmGuXTe73-FbY4lnpMj1v5MnjhnO61ATot6AJCwXbK5XCeb3ETkQdR72ByYvkUcYG-yLEQbayLYcujmKELxnzjQX7Jo1g8aQ",
"payload": ""
2020-07-28 14:17:25,624:DEBUG:urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/order/14834518/121986950 HTTP/1.1" 200 460
2020-07-28 14:17:25,625:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Tue, 28 Jul 2020 04:17:25 GMT
Content-Length: 460
Replay-Nonce: 0001AktCDzD9LHs-m0hoCcY4qY0ptsQpUC-wY01Kbfy6SIM
"status": "valid",
"identifiers": [
"type": "dns",
"authorizations": [
2020-07-28 14:17:25,625:DEBUG:acme.client:Storing nonce: 0001AktCDzD9LHs-m0hoCcY4qY0ptsQpUC-wY01Kbfy6SIM
2020-07-28 14:17:25,625:DEBUG:acme.client:JWS payload:
b''
2020-07-28 14:17:25,626:DEBUG:acme.client:Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/cert/fa6452755670e6763970b37a7d35646ff5e3:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNDgzNDUxOCIsICJub25jZSI6ICIwMDAxQWt0Q0R6RDlMSHMtbTBob0NjWTRxWTBwdHNRcFVDLXdZMDFLYmZ5NlNJTSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9jZXJ0L2ZhNjQ1Mjc1NTY3MGU2NzYzOTcwYjM3YTdkMzU2NDZmZjVlMyJ9",
"signature": "WFSpjlpZIqpY-3h_hSeATiqVY9wl4rV5QTIZ3aFcW3EMzNoBV4iT6FRKCNznnvMCRS5nsMCwdAA25WvkqCwLb1y8FB09uuAvpdqpoher0HCSOvZ9-CP7mRGCHe92EQiW0yRjszsFJFBTwYjZihnvj4caVaZjFHzQi8ieSNO5rlC2z7mjL9KPfPdB4RxTRGIMVZdFKp1piU6U1xIzRiSLu8N2bxRUXOSc3F8sKXSx_i8fyb4cxxCILZv6p5axGMUORjF7wa8SlbeImt07VxkktU1Dl6NvwPnBsil95Z85E_UfZsd1eAJGbzYB0MdOc1gmc9XunanE3QLw7D1LV-KAYg",
"payload": ""
2020-07-28 14:17:25,839:DEBUG:urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/cert/fa6452755670e6763970b37a7d35646ff5e3 HTTP/1.1" 200 3554
2020-07-28 14:17:25,839:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Type: application/pem-certificate-chain
Content-Length: 3554
Link: <https://acme-staging-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-staging-v02.api.letsencrypt.org/acme/cert/fa6452755670e6763970b37a7d35646ff5e3/1>;rel="alternate"
Replay-Nonce: 0001H6oL85J5jhhn9_2Q-W6gUciiDPqyYL808hMuzYmmaJA
-----BEGIN CERTIFICATE-----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=
-----END CERTIFICATE-----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=
2020-07-28 14:17:25,839:DEBUG:acme.client:Storing nonce: 0001H6oL85J5jhhn9_2Q-W6gUciiDPqyYL808hMuzYmmaJA
2020-07-28 14:17:25,840:INFO:certbot.client:Non-standard path(s), might not work with crontab installed by your operating system package manager
2020-07-28 14:17:25,840:DEBUG:certbot.storage:Archive directory /etc/letsencrypt/config/archive/slayer.noojee.org and live directory /etc/letsencrypt/config/live/slayer.noojee.org created.
2020-07-28 14:17:25,840:DEBUG:certbot.storage:Writing certificate to /etc/letsencrypt/config/live/slayer.noojee.org/cert.pem.
2020-07-28 14:17:25,841:DEBUG:certbot.storage:Writing private key to /etc/letsencrypt/config/live/slayer.noojee.org/privkey.pem.
2020-07-28 14:17:25,841:DEBUG:certbot.storage:Writing chain to /etc/letsencrypt/config/live/slayer.noojee.org/chain.pem.
2020-07-28 14:17:25,841:DEBUG:certbot.storage:Writing full chain to /etc/letsencrypt/config/live/slayer.noojee.org/fullchain.pem.
2020-07-28 14:17:25,841:DEBUG:certbot.storage:Writing README to /etc/letsencrypt/config/live/slayer.noojee.org/README.
2020-07-28 14:17:25,846:DEBUG:certbot.plugins.selection:Requested authenticator manual and installer <certbot.cli._Default object at 0x7f9108098100>
2020-07-28 14:17:25,846:DEBUG:certbot.cli:Var staging=True (set by user).
2020-07-28 14:17:25,846:DEBUG:certbot.cli:Var server={'staging', 'dry_run'} (set by user).
2020-07-28 14:17:25,846:DEBUG:certbot.cli:Var account={'server'} (set by user).
2020-07-28 14:17:25,846:DEBUG:certbot.cli:Var pref_challs=dns (set by user).
2020-07-28 14:17:25,846:DEBUG:certbot.cli:Var config_dir=/etc/letsencrypt/config (set by user).
2020-07-28 14:17:25,846:DEBUG:certbot.cli:Var work_dir=/etc/letsencrypt/work (set by user).
2020-07-28 14:17:25,846:DEBUG:certbot.cli:Var logs_dir=/etc/letsencrypt/logs (set by user).
2020-07-28 14:17:25,846:DEBUG:certbot.cli:Var authenticator=manual (set by user).
2020-07-28 14:17:25,846:DEBUG:certbot.cli:Var manual_auth_hook=/home/bin/certbot_hooks/dns_auth (set by user).
2020-07-28 14:17:25,847:DEBUG:certbot.cli:Var manual_cleanup_hook=/home/bin/certbot_hooks/dns_cleanup (set by user).
2020-07-28 14:17:25,847:DEBUG:certbot.cli:Var manual_public_ip_logging_ok=True (set by user).
2020-07-28 14:17:25,847:DEBUG:certbot.storage:Writing new config /etc/letsencrypt/config/renewal/slayer.noojee.org.conf.
2020-07-28 14:17:25,848:DEBUG:certbot.reporter:Reporting to user: Congratulations! Your certificate and chain have been saved at:
Your cert will expire on 2020-10-26. To obtain a new or tweaked version of this certificate in the future, simply run certbot again. To non-interactively renew *all* of your certificates, run "certbot renew"
