Never ended up being a problem… thanks all.
Hi @ihasamoose
that can't work. You would need a certificate with an ip address as domain name. But you can't create a Letsencrypt certificate with an ip address.
PS: Checking your domain there is no redirect to an ip address visible - https://check-your-website.server-daten.de/?q=vault.ihasamoose.ca
And the Chrome screenshot works.
Hi Juergen.
I was experimenting earlier with the raw ip of the server, and I was getting the errors because I was still connecting to the raw IP.
Looks like if I connect to the new subdomain I made and registered the SSL cert, it doesn’t throw errors anymore… so I think it’s actually working… hoorah!
Yes, Grade A, that's good, very good.
