My domain is: https://replyreach.app
I ran this command: sudo certbot renew --dry-run *test
It produced this output: Simulating renewal of an existing certificate for replyreach.app Failed to renew certificate replyreach.app with error: Could not bind TCP port 80 because it is already in use by another process on this system (such as a web server). Please stop the program in question and then try again.
My web server is: (locally hosted apache web server behind Cloudflare tunnel)
The operating system my web server runs on: Ubuntu 22.04.1 LTS - Jammy
I can login to a root shell on my machine: Yes
The web server is hosted in my home behind a Cloudflare zero trust tunnel. My workaround this is a manual process on every renewal, but I am hoping to somehow fine an automatic solution? The manual process works. This is the process:
- Change Cloudflare tunnel to HTTP
- sudo service apache2 stop (to clear port 80)
- sudo certbot renew (wait for it to renew)
- Change Cloudflare tunnel back to HTTPS
- sudo service apache2 start
Not an expert with Linux or SSL If anyone knows of a better way to do this, please let me know. Thanks
