My domain is: springwood.me
I ran this command: certbot renew --dry-run
Processing /etc/letsencrypt/renewal/springwood.me.conf
Simulating renewal of an existing certificate for springwood.me
Failed to renew certificate springwood.me with error: Could not bind TCP port 80 because it is already in use by another process on this system (such as a web server). Please stop the program in question and then try again.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/springwood.me/fullchain.pem (failure)
My web server is (include version): OpenLiteSpeed 1.7.16
The operating system my web server runs on is (include version): CentOS 7.9
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.31.0
The following is my description
The 80 port of my server is already used.
If I manually turn off the existing server on port 80, then it runs OK.
However I hope it can automatically run without manually turning on/off the existing server. Currently certbot has installed a timer on my system.
# systemctl list-timers
NEXT LEFT LAST PASSED UNIT ACTIVATES
Mon 2022-10-31 14:34:03 JST 5h 10min left Sun 2022-10-30 14:34:03 JST 18h ago systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
Mon 2022-10-31 14:41:00 JST 5h 17min left Mon 2022-10-31 00:56:13 JST 8h ago snap.certbot.renew.timer snap.certbot.renew.service
2 timers listed.
What should I do to modify the timer script?
