LetsEncrypt SSL on ISPConfig 3.1
I have 3 accounts setup on ISPConfig and using the LetsEncrypt SSL for all three domains, but the Auto SSL update process failed each time with following error.
Failed authorization procedure. domain.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://domain.com/.well-known/acme-challenge/MKSe9cFzMXVQu3niTuds8P_0FTedATwAil_L_ggWKFw:
<ht”
I have to do the following manual changes and re-initiate the LetsEncrypt SSL generate command to manually create new SSL.
  1. I have to create symlink of .well-known to point it to website for which I want to renew SSL inside
    /usr/local/ispconfig/interface folder.
steps: cd /usr/local/ispconfig/interface
ln -s /var/www/clients/client1/web1/web/.well-known/
  1. Create symlink of .well-known to point it to website for which I want to renew SSL inside /usr/local/ispconfig/interface/acme/ folder
steps: cd /usr/local/ispconfig/interface/acme/
  1. re-issue the lets encrypt command to generate the SSL again
I have to do the same think when next domain’s SSL get expire, is there any automated fix for this issue ?
My domain is: equinetreatments.com
I ran this command: ./letsencrypt-auto --text --agree-tos --email certonly --renew-by-default --webroot --webroot-path /var/www/clients/client1/web1/web -d equinetreatments.com -d equinetreatments.com
http-01 challenge for equinetreatments.com
Using the webroot path /var/www/clients/client1/web1/web for all unmatched domains.
Waiting for verification…
Generating key (2048 bits): /etc/letsencrypt/keys/0009_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0009_csr-certbot.pem
  • Congratulations! Your certificate and chain have been saved at
    /etc/letsencrypt/live/equinetreatments.com/fullchain.pem. Your cert
    will expire on 2017-07-21. To obtain a new or tweaked version of
    this certificate in the future, simply run letsencrypt-auto again.
    To non-interactively renew all of your certificates, run
    "letsencrypt-auto renew"
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
My operating system is (include version): Debian GNU/Linux 7 \n \l
Server version: Apache/2.2.22 (Debian)
Server built: Jul 20 2016 05:07:11
My hosting provider, if applicable, is: AWS
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Yes, I can use both control panel and shell.
Please be informed that I do not have problem to generate the new SSL, the auto generation of SSL after 90 day is the main problem. As previously said I have to add those symlynks before I re-generate the LetsEncrypt
Does the symlink somehow get deleted in between the time that you issue the certificate and the time that you want to renew it?
